4door exhausts
Old Aug 11, 2003 | 02:28 PM
S13 slide's Avatar
Default 4door exhausts
does the 88-91 civic 4door rear muffler section bolt up to the hatchback? mine fell off and the junk yards only have 4doors. thanks
Old Aug 11, 2003 | 02:43 PM
EP3_05's Avatar
Default Re: 4door exhausts (S13 slide)
The pipe after the muffler is going to be too long and the hanger that hangs the pipe with the tip on it is different.
Old Aug 11, 2003 | 06:46 PM
CdTriX's Avatar
your junkyard onl yhas 4drs? where is this junk yard cause EVERYWHERE all you can find are freaking HBs!! EVERYWEHRE!!!
i need my damn rear door mouldings back.. BOTH SIDES
Old Aug 11, 2003 | 10:05 PM
SMZ GSR's Avatar
going to that junkyard again anytime soon? i can never find the 4dr parts i need for my civic.
Old Aug 11, 2003 | 11:52 PM
uneek4dr's Avatar
Default Re: 4door exhausts (SMZ GSR)
check my post haha i am parting my sedan out
Old Aug 12, 2003 | 06:33 AM
S13 slide's Avatar
Default Re: 4door exhausts (uneek4dr)
well now, would the 4door hood and windsheild fit hatches? im going there today to look for those two items because i forgot to lock my hood pins and my hood busted my windsheild hahaha o well, i guess email me what u need and i'll see if its still there.
S13Slide@yahoo.com
Old Aug 12, 2003 | 06:47 AM
E-AT_me's Avatar
nope.. 4 door is basically a car in it's own..
Old Aug 12, 2003 | 07:11 AM
ex voto's Avatar
Default Re: 4door exhausts (Rexman)
I drive an EX... I had a hard time finding a direct fit converter to work.
Had to MAKE one work... hmph.
Old Aug 13, 2003 | 09:58 AM
S13 slide's Avatar
Default Re: 4door exhausts (ex voto)
so im guessing that if the hood's diffrant then the headlights from a 4dr wont work on a hatch?
Old Aug 13, 2003 | 05:48 PM
KOOL-AID's Avatar
no the head lights are the same and the hoods on civic hb are about 1/2" inch longer thats all not to much of a difference but the headlights are the same the corners are different in each model!!!
Old Aug 13, 2003 | 06:36 PM
4genaccordfreak's Avatar
the hood will need alil fiddling with for placement.. get a friend to help you so u don't kill yourself.. ahah.. have fun
Old Aug 14, 2003 | 10:40 AM
S13 slide's Avatar
Default Re: 4door exhausts (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">The pipe after the muffler is going to be too long and the hanger that hangs the pipe with the tip on it is different.</TD></TR></TABLE>
sooo is too long on the muffler tip part? if so i'd just be able to cut it. then have a a hanger welded inplace correct? then it should fit? thanks
crimzon
Honda Civic (2006 - 2015)
Oct 15, 2009 04:49 PM
gqstatus05
Oct 6, 2008 02:50 PM
Libertariat
Oct 27, 2006 10:41 PM
EP_EJAY
Feb 1, 2006 11:02 AM
Hcivic88
May 17, 2002 02:02 PM
