i need help!! my left turn signal is staying on!!!!!!!!
i am in the process of returning my car back to its stock form but a few weeks ago for some reason to which i wasnt aware, i was driving home and suddenly my left turn signal light inside my gauge cluster was just on and when i click the turn signal to go left it just gets stuck, this is only when i have my night time lights on is when this happens, during the day the blinker will go of but the radio light and lights from the a/c display blink along with it, i checked the turn signal relay and there was no problem there, im not sure if its a fuse or not, i will try later. do u guys have any suggestions????? its very annoying having this problem!!!!!!!!!
A component in the cars electrical systems is "back feeding" electricity from another device in the vehicle... This is always the problem when you notice multiple electrical problems when a certain component is used... 2 things will create this...
1) Blown fuse somewhere in the circuit
2) insufficient ground terminal within the system..
and make sure no fuses are missing!
[Modified by BreakStuff, 10:25 PM 8/10/2001]
I hate having bad grounds, it is the last thing you think to look at after 10 hours of fuxoring with the car!
