fastest 18c1 in a integra body?
Old Aug 10, 2003 | 09:06 PM
g5r's Avatar
g5r
Default fastest 18c1 in a integra body?
i was wondering who have the fastest(quarter mile) integra gsr in here, all motor. btw i want to know the ones with stock bottom end, only headwork and bolt on.
Modified by g5r at 5:05 AM 8/12/2003
Old Aug 10, 2003 | 10:11 PM
94gsr4dr's Avatar
Default Re: fastest 18c1 in a integra body? (g5r)
does weight matter, and you say headwork i assume that means cams, but stock compression huh. I am somewhat interested as well. Any full interior stock compression gsr's runnin 12's?
Old Aug 11, 2003 | 08:19 AM
g5r's Avatar
g5r
weight don't matter. however compression be be rasie by a thin headgasket.
Old Aug 11, 2003 | 04:32 PM
96dc2's Avatar
Default Re: (g5r)
Check this guy out. He's on this board. Goes by GZR4DR.
Old Aug 11, 2003 | 08:07 PM
g5r's Avatar
g5r
that is some crasy *** motor. And its has a stock bottom ends. i wonder what kind of times he run.
Old Aug 12, 2003 | 02:00 PM
igotyofire's Avatar
Default Re: (g5r)
hmmz he used a ITR intake manifold on a GSR head never heard of that being done, i would think it would be cheaper just to go out and by the skunk2 intake manifold, then no machining needed
Old Aug 12, 2003 | 03:42 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering who have the fastest(quarter mile) integra gsr in here, all motor. btw i want to know the ones with stock bottom end, only headwork and bolt on.
Modified by g5r at 5:05 AM 8/12/2003</TD></TR></TABLE>
I have a poor man's ITR setup in a 94 DC chassis running 12's.
12:5 compression, Head work and bolt on's
Old Aug 12, 2003 | 05:40 PM
sander's Avatar
2.7(p/t)
Default Re: fastest 18c1 in a integra body? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
12:5 compression, Head work and bolt on's</TD></TR></TABLE>
what transmission/diff are you running?
-sander
Old Aug 12, 2003 | 05:42 PM
96dc2's Avatar
Default Re: (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">hmmz he used a ITR intake manifold on a GSR head never heard of that being done, i would think it would be cheaper just to go out and by the skunk2 intake manifold, then no machining needed</TD></TR></TABLE>
If you read closer, he states at the time the Skunk2 IM did not come out yet.
Old Aug 12, 2003 | 05:49 PM
skunked's Avatar
Default Re: fastest 18c1 in a integra body? (jazzyfoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazzyfoo &raquo;</TD></TR><TR><TD CLASS="quote">
-sander</TD></TR></TABLE>
Stock Y80 tranny.
Old Aug 12, 2003 | 05:51 PM
sander's Avatar
2.7(p/t)
Stock Y80 tranny.</TD></TR></TABLE>
very impressive, nice work!
-sander
Old Aug 12, 2003 | 06:45 PM
g5r's Avatar
g5r
thats is nice and props to the time, however i wanted to know a setup with stock bottom end.
Old Aug 12, 2003 | 07:12 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5r &raquo;</TD></TR><TR><TD CLASS="quote">thats is nice and props to the time, however i wanted to know a setup with stock bottom end.</TD></TR></TABLE>
why do you want to know about setups only with stock bottom end?
why no just ask for fastest 1.8L integra?
Old Aug 13, 2003 | 10:36 AM
skunked's Avatar
Default Re: fastest 18c1 in a integra body? (ALLMOTOR18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR18 &raquo;</TD></TR><TR><TD CLASS="quote">
I agree, I don't think he understands that a GSR block with ITR pistons is basically a stock ITR block (same stroke, bore and compression)
Old Aug 13, 2003 | 08:10 PM
H25's Avatar
H25
Sheng Chao Lucky racing 1995 GSR stock b18c1 block....12.2@110mph feb 1998 bakersfield raceway
Old Aug 13, 2003 | 11:29 PM
igotyofire's Avatar
Default Re: fastest 18c1 in a integra body? (LuckyRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LuckyRacing &raquo;</TD></TR><TR><TD CLASS="quote"> Sheng Chao Lucky racing 1995 GSR stock b18c1 block....12.2@110mph feb 1998 bakersfield raceway </TD></TR></TABLE>
heh and how was that done, info on the setup?
Old Aug 14, 2003 | 07:03 AM
g5r's Avatar
g5r
QUOTE=skunked]
I agree, I don't think he understands that a GSR block with ITR pistons is basically a stock ITR block (same stroke, bore and compression) [/QUOTE]
Because i asked what the fastest b18c1 with no bottom end work, no pistons, rods, and etc. I just want to know how far my setup can go, however i know it can`t hit 12's.
Old Aug 14, 2003 | 10:07 AM
skunked's Avatar
[/QUOTE]Because i asked what the fastest b18c1 with no bottom end work, no pistons, rods, and etc. I just want to know how far my setup can go, however i know it can`t hit 12's. [/QUOTE]
OK, I thought I saw C5 in your original post...........
goodluck
Old Aug 14, 2003 | 04:17 PM
Mr Hammond's Avatar
a/k/a Jomo
I've seen 13.60 @ 104mph out of a 95 coupe with Headlight mod, 64mm TB/Skunk2 IM/Skunk2 Stage 1's/DC JDM 4-1 open/FPR/Cam Gears/Prelude 290's/Chipped P28/VAFC tuning/Clutch & Flywheel/CTR N1 crank pulley/no passenger seat, back seat & stripped hatch. I think that is it. I've talked to the guy the last two times I went to the track. Run's consistant as hell to. I was very impressed on 16" Volk's w/ 215 Azenis no less.
Old Aug 14, 2003 | 10:47 PM
H25's Avatar
H25
Default Re: fastest 18c1 in a integra body? (igotyofire)
That was my freinds car. back then it was a fast street car. now its a full race car.. It ran a stock c1 block, with headwork, ctr cams, 4-1 header,Fpr, just basics.. the car had a lexan rear hatch and cut out doors... this was done 5-6 years ago... way before the big cams, better heads, etc came out..
Max-
Old Aug 15, 2003 | 05:25 PM
g5r's Avatar
g5r
anybody else?
Old Aug 15, 2003 | 07:07 PM
B18C2's Avatar
my friends GSR all stock nothing at all not even intake all stock he run 15.1
Old Aug 18, 2003 | 07:35 PM
g5r's Avatar
g5r
thats cool
IntegraDL
Feb 15, 2008 03:35 PM
ef8-dc2619
Mar 19, 2007 10:52 AM
HONDA RR
Jul 3, 2005 11:31 PM
acuraqc
Feb 16, 2004 08:15 PM
