After a month the R is finally back on the road...
Old Aug 10, 2003 | 02:00 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default After a month the R is finally back on the road...
Finally, my car is fixed and running again. After intially thinking it was a fuel problem to later finding out my T belt had slipped and nicked my exhaust valves the car has been down for 1 month 3 days.
I'm sorta glad it happened for the learning experience of pulling the head, which is not very hard at all IMO. It still took me a while of course because I'm forgetful and I like rechecking everything, but all in all it went pretty smooth. It also saved me around $900 and the dealer didn't include a new T belt, water pump, or Portflow inners in the cost.
Few funny moments. After everything was ready to go the big moment came. I turned the key and.....nothing . Looked at my fuel pressure guage and saw 0. Then I decided that maybe the car needed the EFI fuse, just a guess. The car actually started up this time and hunted around for idle, then started revving up and down to 2,500rpms . I checked the VAFC and all my settings had been erased and it was set for a 6 cylinder. Fixed that and the car still kept doing the same thing. By this time I was getting pretty worried as I hunted around for a missed vacuum line. After checking over everything I noticed the map sensor plug wiring had little slack while the TPS had alot. I switched them around and the car fired right up. Functioning MAP sensor, who needs it.
I also aced the valve adjustment, thanks to my new snap-on rip off tool. The car actually doesn't tick, so nice. Replaced my cam gear bolts with some new ones that are easier to adjust (hex head).
Getting back in the R after driving around my moms TL (not that its a bad car) and an F150 makes me love it even more.
Tommorrow I should be hitting the dyno again and I'll post up some numbers. This time I'm actually going to tune the cam gears. Hoping for 190whp (crosses fingers).
Old Aug 10, 2003 | 02:05 PM
bartek_b's Avatar
Default Re: After a month the R is finally back on the road... (ActiveAero)
what tool did u use as you refered to it as the
"snap-on rip off tool"
congrats man, I've done my own valve adjustment, took 2 hours and still did it wrong. Dad came home and 30 min and it was runing fine.
Old Aug 10, 2003 | 02:16 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: After a month the R is finally back on the road... (mugen85r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen85r &raquo;</TD></TR><TR><TD CLASS="quote">what tool did u use as you refered to it as the
congrats man, I've done my own valve adjustment, took 2 hours and still did it wrong. Dad came home and 30 min and it was runing fine.</TD></TR></TABLE>
Just search under my name, I just posted about it a few days ago. It's nice and only cost me $38 minus shipping. WAAAAY better than trying to use an open end wrench and screwdriver like I did last time.
Old Aug 10, 2003 | 02:19 PM
canuckr's Avatar
Congrats on getting it running. I pulled my head for the first time this summer and learned alot also ! However mine wasnt so smooth; one problem after another.
Old Aug 10, 2003 | 07:16 PM
Type-R Yo!'s Avatar
New User
Default Re: After a month the R is finally back on the road... (canuckr)
Congrats
Old Aug 10, 2003 | 08:26 PM
Eva01's Avatar
Default Re: After a month the R is finally back on the road... (Type-R Yo!)
Car back in action after a month long vacation eh ...Aren't DIY Integra projects fun!!
Old Aug 10, 2003 | 10:36 PM
NA gs-R 05 C
Guest
Posts: n/a
glad its up and running again, 1 month and a few days is pretty long.
Old Aug 11, 2003 | 12:57 AM
kkim's Avatar
congrats on getting the problems sorted out and the car back up and running.
lizard928s
Honda CR-V & Element
Aug 18, 2010 12:15 PM
SpOoLiNg CiViC
Jan 13, 2007 07:44 PM
PA MATT
Oct 7, 2004 01:31 PM
Steve90HB
Aug 24, 2003 12:33 PM
