CEL help... ----> confused
Old Aug 10, 2003 | 11:56 AM
B_CRUZ!'s Avatar
Default CEL help... ----> confused
I hit a bump and Check Engine Light comes on. The weird thing is when I go to check for the code, the light doesn't blink. It just stays on. Whats going on?
Thanks.. .
b.cruz
Old Aug 10, 2003 | 12:13 PM
acuracing's Avatar
Default Re: CEL help... ----> confused (b.cruz)
Try resetting the ECU and see if the light comes up again. You're not starting the car are you, just turning it to the "on" position right?
Old Aug 10, 2003 | 12:29 PM
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing &raquo;</TD></TR><TR><TD CLASS="quote"> You're not starting the car are you, just turning it to the "on" position right?</TD></TR></TABLE>
yup just on the 'ON' position. its weird.
has this ever happened to any one else?
Old Aug 10, 2003 | 12:33 PM
ATS*Mark's Avatar
OG triple OG
damn B , ive never herd of that
Old Aug 10, 2003 | 12:35 PM
Chris y0!'s Avatar
i heard it means you need to check your engine
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (TURSpoonEK)
bahh... I'll reset it later and see what happens. weird thing is it happens after I hit a bump on road usually at about 35-40mph. probably just a fukt connection in wiring or something.
Old Aug 10, 2003 | 12:36 PM
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">i heard it means you need to check your engine</TD></TR></TABLE>
bah ha ha ha
Old Aug 10, 2003 | 12:41 PM
Stupid Ass's Avatar
O2 Sensor?
Old Aug 10, 2003 | 12:45 PM
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (MooreVTEC)
well I had a 02 code a week ago (and when I checked for a cel it would blink '1')but I replaced my exhaust manifold on friday with a 02 in it already. It worked fine and yes I did reset the CEL after I swapped mani's and 02.
BTW 2.5 collector and exhaust rocks!
Old Aug 10, 2003 | 03:08 PM
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (b(series)cruz)
bump for some insight
Old Aug 10, 2003 | 03:19 PM
slvrcivic97's Avatar
youre probably right about some kind of loose connection...
Old Aug 10, 2003 | 03:59 PM
Ricey McRicerton's Avatar
Default Re: CEL help... ----> confused (slvrcivic97)
Mine was doing the same thing when my secondary 02 sensor was dying (the no blinks, not the over the bump thing)
Old Aug 10, 2003 | 04:05 PM
B_CRUZ!'s Avatar
Default Re: CEL help... ----> confused (Ricey McRicerton)
well I have come to the conclusion that it is just some fluke. I reset the ECU checked for a CEL... same thing. CEL on no blink. Meaning that when there are no codes to be pulled, it just stays on when the connecter gets jumped.
weird stuff. If my drive home tonight doesn't go smoothly, I'll definately post more about this...
ITRiWISH
11
Aug 27, 2007 05:24 PM
BseriesHeaven
May 22, 2007 08:01 PM
Quade
Nov 24, 2005 12:15 PM
game over
Feb 19, 2005 06:15 PM
ErikDaGenErik
Nov 10, 2003 04:57 PM
