Water leaking into car when AC is on... HELP!
Old Aug 10, 2003 | 10:48 AM
Double_Dk's Avatar
Default Water leaking into car when AC is on... HELP!
Hey all. I just got my AC refilled. Now, when I am sitting in my "Cool" car, water will start dripping and sometimes pour out are the passenger side and at the middle of the car near my gas pedal. What could be causing this? Anyone????
Old Aug 10, 2003 | 11:09 AM
oldB18EF's Avatar
Default Re: Water leaking into car when AC is on... HELP! (Double_Dk)
bump for you, id be pissed if this was happening to me
Old Aug 10, 2003 | 11:22 AM
tallblondkid's Avatar
is it alot, or is it just little drops, cuz that was happenin to me when i got my ac fixed, and it went away after a lil while
Old Aug 10, 2003 | 11:26 AM
t0p_sh0tta's Avatar
Default Re: Water leaking into car when AC is on... HELP! (tallblondkid)
There's a drain hose that runs from the HVAC unit through the firewall. Sometimes it cloggs and leaks water into the car. If yo get down on the passenger side you should be able to see it.You can use some compressed air to clear it out.
Old Aug 11, 2003 | 07:53 AM
Double_Dk's Avatar
Well, sometimes it just drips every now and then, but other times, it's like a solid stream for a few secs. Good enough to get your foot wet.
What do you guys think
Old Jun 30, 2004 | 07:34 PM
buzzsawstan's Avatar
Default Re: Water leaking into car when AC is on... HELP! (t0p_sh0tta)
I have this same problem. Were you able to fix this by using compressed air as the post stated? thx
stan
Old Jun 30, 2004 | 08:34 PM
DavidR's Avatar
either the hose mentioned above it clogged, or is disconnected. AC evaporators remove moisture from the air, that is the water dripping. Clean the tube and make sure it is connected.
metalmole
Honda Civic (2001 - 2005)
Jun 18, 2014 10:30 PM
DACteg
Jul 27, 2010 11:04 AM
No-Gi
Oct 3, 2009 06:30 AM
adrenalinesaint
Aug 30, 2007 11:23 AM
gtowni3
Oct 5, 2004 06:19 PM
