JDM ITR Tranny Help
Old Aug 10, 2003 | 06:49 AM
ITR RACER's Avatar
Default JDM ITR Tranny Help
I'm trying to figure out what the problem is with this jdm itr tranny w/4.785 FD i picked up last week.
Looks like i cannot get it to go into gear. It goes into 4th and reverse but not any other gear. Whether you depress the clutch or not, it doesn't make a difference. I checked the shift linkage and everything is aligned and in place, the clutch slave cylinder is bled and everything looks fine. I tooj the tranny back out to ensure i installed it correct and it looks fine.
Keep in mind, i had a tranny(4.5 FD) in before, and everything worked fine. The clutch is practically new. I can return it to get my old tranny back but i prefer to see if i can fix this (depending on price) so i can have the 4.8 fd.
Any ideas? Could the gears just be messed up?
Old Aug 10, 2003 | 06:54 AM
Ausmith's Avatar
Default Re: JDM ITR Tranny Help (ITR RACER)
Sounds like a clutch problem or perhaps the tranny is a little crooked - if the linkage is moved just a little bit it can prevent the car from going into gear.
Old Aug 10, 2003 | 07:56 AM
92TypeR's Avatar
FSAE
Default Re: JDM ITR Tranny Help (Ausmith)
I had a similar problem with the tranny I got with my JDM ITR swap years ago...it had a bent shift fork. Hopefully it is something much easier to fix for you.
Old Aug 10, 2003 | 08:01 AM
GIZZ - EXV's Avatar
Loved
sounds internal. see if you can buy the core and get your old one back.
sell it to me garettm@direct.ca
JRSC01GS-R
Transmission & Drivetrain
Apr 13, 2014 04:35 PM
phelpsj2
May 18, 2010 03:40 PM
vtecmissle
Nov 15, 2004 02:26 PM
fabshybrid
Oct 2, 2004 12:03 PM
ssacol
Dec 9, 2003 07:07 AM
