[FAQ] EK sidemarker diagram
Old Aug 9, 2003 | 08:47 PM
quanx22's Avatar
Default EK sidemarker diagrams??
hey does anyone have EK sidemarker diagrams? or should i just eyeball it...
thanks
Old Aug 9, 2003 | 08:49 PM
Draggin99Si's Avatar
Default Re: EK sidemarker diagrams?? (quanx22)
Are you referring to the cutout diagram or the placment on the fender?
Old Aug 9, 2003 | 08:50 PM
EKtypeRhaTcH's Avatar
i would like to know this also, i think hes talkin about the placement on the fender
Old Aug 9, 2003 | 08:53 PM
Default Re: (EKtypeRhaTcH)
If he's talking about the placement location on the fender, then I have some pics that I snapped a year ago of my friend's Si that had this professionally done. It turned out really nice.
Old Aug 9, 2003 | 09:11 PM
quanx22's Avatar
Default Re: (Draggin99Si)
yea thats wat i mean...i need to place them on my fender
Old Aug 9, 2003 | 09:26 PM
slvrcivic97's Avatar
Default Re: (quanx22)
The Center of the ek9/ek4 sidemarker should be where the top of the wheel well meets with the bottom front of the sideskirt. Here's a pic of my measurement:
Old Aug 9, 2003 | 09:28 PM
thanx a lot
Old Aug 9, 2003 | 09:32 PM
2000CX's Avatar
slvrcivic97...so where those two lines cross should be dead center on the actual lense? i've had mine sitting here for months waiting to get a straight answer on placement.
Old Aug 9, 2003 | 09:34 PM
Default Re: (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">slvrcivic97...so where those two lines cross should be dead center on the actual lense? i've had mine sitting here for months waiting to get a straight answer on placement.</TD></TR></TABLE>
Yes sir.
Old Aug 9, 2003 | 09:37 PM
2000CX's Avatar
Default Re: (slvrcivic97)
thank you much
Old Aug 9, 2003 | 09:38 PM
Here's a pic of it installed.
Old Aug 9, 2003 | 09:42 PM
oh yeah, and just a few tips...I used one of those guages with bubble in them to make sure I got the line straight across from the wheel well.Use Radioshack's Metal Nibbler (10.00) to cut the hole out It's clean and takes time but makes the job ALOT easier. And also, I used some plummer's putty around my sidemarkers just in case to keep any water from entering. Not even noticeable. Oh yeah, before you start cutting, I would put clear tape right over your mark you're going to cut. This prevents any paint chipping. Worked great for me. THen peel it off after your finished. And then when you are finished cutting out the hole, put touch up paint if you have some handy around the bare metal. probably not needed either, but it's just an extra thing you can do to help it.
Modified by slvrcivic97 at 4:11 PM 8/10/2003
Old Aug 12, 2003 | 07:38 PM
quanx22's Avatar
thanks a lot man... just like regular scotch tape? or like clear tape you use to box up a box?
thanks a lot for the diagrams
Old Aug 12, 2003 | 07:45 PM
2000CX's Avatar
since its up...how about wiring? are you guys wiring right off the headlight? i've read this is easy to do...seems pretty logical considering how close they are to the headlights. now i just have to get the stones to cut big holes in my fenders
Old Mar 4, 2004 | 05:58 PM
jeremy.'s Avatar
up so i can read later
Old Mar 4, 2004 | 06:00 PM
diearzte2
Guest
Posts: n/a
Default Re: EK sidemarker diagrams?? (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">up so i can read later</TD></TR></TABLE>
Edit: removed a comment of mine to prevent an unnecessary flamewar. Just bookmark it next time man.
Old Mar 25, 2005 | 09:32 AM
integraXTC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">since its up...how about wiring? are you guys wiring right off the headlight? i've read this is easy to do...seems pretty logical considering how close they are to the headlights. now i just have to get the stones to cut big holes in my fenders </TD></TR></TABLE>
Old May 10, 2006 | 10:35 PM
vincentek9's Avatar
Default Re: (integraXTC)
i have the actual measurements for the sidemarker placement if you guys still want it.
Old May 11, 2006 | 02:07 AM
jumai182's Avatar
Default Re: (vincentek9)
What is it? How much different is it then the fender/skirt method?
Old May 12, 2006 | 01:25 PM
jumai182's Avatar
Default Re: (jumai182)
Up for vincenteks response.
Old Dec 15, 2006 | 12:25 AM
1EK1EG's Avatar
I realize this a very old thread,but I was wondering if this same method could be used to measure the location of the jdm sidemarkers on EGs as well.There was a link before,but I can't seem to find it.Ill try moving some words around and continue my search for an answer.
Old Dec 15, 2006 | 01:28 AM
bigwhitebucket's Avatar
Default Re: (1EK1EG)
https://honda-tech.com/zerothread?id=1768387
Old Dec 15, 2006 | 07:36 AM
1EK1EG's Avatar
Thank you kind sir,your direction to the link is greatly appriciated.Thank you again.
Old Mar 19, 2007 | 12:35 PM
99_EM_one's Avatar
thanks for the info!!!
Old Mar 19, 2007 | 12:36 PM
99_EM_one's Avatar
thanks for the pic that was what i looking for!
00b18ek
Jun 2, 2008 03:43 PM
2000si
Apr 4, 2006 08:46 PM
MB4
Mar 7, 2004 08:48 PM
K-Bom05
May 8, 2003 09:25 AM
