Header install... what do you use to clean?
Old Aug 9, 2003 | 08:43 PM
b18c1eg
Guest
Posts: n/a
Default After header install... what do you use to clean?
I just installed my JDM Apex GT header on my Type R. Of course there is oil from our hands on the pipes from the install, so I know I need to clean it off. What is the best cleaner to use on the header that will not discolor it once I turn the car on. I need to clean it ASAP so I don't have burned in hand prints all over it. lol
Thanks,
Brad
Old Aug 9, 2003 | 08:48 PM
b19coupe's Avatar
Default Re: After header install... what do you use to clean? (b18c1eg)
Brake clean works for me, no residue.
Old Aug 9, 2003 | 08:52 PM
cjohnson_2's Avatar
Default Re: After header install... what do you use to clean? (b19coupe)
Acetone
Old Aug 9, 2003 | 09:06 PM
Tweakmeister's Avatar
Default Re: After header install... what do you use to clean? (cjohnson_2)
I just use Windex and a paper towel
Old Aug 9, 2003 | 09:16 PM
Jason's Avatar
I used a metal polish called Flitz even after the car was started...got most of the discoloration off of my header...it can be purchased at most marine shops
Old Aug 9, 2003 | 09:46 PM
Bbasso's Avatar
I heard that plain rubbing alcohol works fine, But yet to see it for myself.
Old Aug 9, 2003 | 09:50 PM
Hybrid ctr's Avatar
Default Re: After header install... what do you use to clean? (Bbasso)
Rubbing alcohol
Old Aug 10, 2003 | 09:40 AM
SlapSmak's Avatar
Default Re: After header install... what do you use to clean? (Hybrid ctr)
denatured alcohol, leaves no residue. It is normally used as a prep solvent for auto painting. wear gloves, it sucks the oil out of your skin also.
Old Aug 10, 2003 | 04:18 PM
Champ R's Avatar
Default Re: After header install... what do you use to clean? (SlapSmak)
I use Mothers metal polish, it works wonders for the header and exhaust... but unfortunately wont get any of the blue marks out on the header.
Old Aug 10, 2003 | 08:19 PM
Mario's Avatar
Default a
Blue Magic METAL POLISH @ Wal Mart works good for me.
Old Aug 10, 2003 | 11:23 PM
rockwilda's Avatar
Default Re: a (Mario)
Rubbing Alcohol.
Old Aug 10, 2003 | 11:24 PM
Ketone's Avatar
I used rubbing alcohol on mine, and I don't think it did that good of a job; there were a lot of finger prints left over.
Old Aug 11, 2003 | 09:05 AM
Default Re: a (Ketone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone &raquo;</TD></TR><TR><TD CLASS="quote">I used rubbing alcohol on mine, and I don't think it did that good of a job; there were a lot of finger prints left over. </TD></TR></TABLE>
The rubbing alcohol was fine, you just couldn't keep your hands off the thing
siRone
Jan 2, 2012 03:53 PM
SiR-T
Oct 27, 2007 08:45 AM
POE
May 2, 2006 12:05 AM
B18CYAAA
Aug 16, 2003 05:13 PM
xjohnx
Nov 2, 2002 08:55 PM
