Valve Covers....
Old Aug 9, 2003 | 06:17 PM
96 Ls lnTeG's Avatar
Default Valve Covers....
Well I am not the smartiest guy but i was just wondering if all valve cover scompatible (I.E. Ls to type R valve cover) just wondering???
Old Aug 9, 2003 | 06:22 PM
Money $hot's Avatar
Default Re: Valve Covers.... (sil2civic)
if the engine is on the same block (IE D, B, H) then valve covers are interchangeable. sohc and dohc engines have different valve covers
Old Aug 9, 2003 | 06:27 PM
Thanks that all i needeed to know thanks
Old Aug 9, 2003 | 07:52 PM
MolecularIntegra's Avatar
Default Re: (sil2civic)
That's not really correct, valve covers are interchanagble between heads, not blocks....for instance, non-vtec and vtec valve covers are not interchangable.
Old Aug 9, 2003 | 08:15 PM
ek9mugen's Avatar
Default Re: (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">That's not really correct, valve covers are interchanagble between heads, not blocks....for instance, non-vtec and vtec valve covers are not interchangable.</TD></TR></TABLE>
true for integra's but not all civics
Old Aug 9, 2003 | 08:20 PM
slowman's Avatar
I took way too long
Default Re: (ek9mugen)
All D Series SOHC VTEC Valvcovers must go on D Series SOHC VTEC head (ie: D16Z6 is compatible with D16y8)
SOHC non-vtec D series valvcovers will work on Sohc D Sereis non-vtec head (ie: D16A6 is compatible with D15)
DOHC VTEC B series vavlecovers will work on all DOHC VTEC B series head (ie: B16 is compatible with B18C)
DOHC non-VTEC b series valvecovers will work on all DOHC non-VTEC B series head (ie: B18A will work on B18B)
Old Aug 9, 2003 | 11:33 PM
illusive's Avatar
Default Re: (slowman)
Slowman is correct on this
Old Aug 10, 2003 | 08:43 AM
hatchback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman &raquo;</TD></TR><TR><TD CLASS="quote">All D Series SOHC VTEC Valvcovers must go on D Series SOHC VTEC head (ie: D16Z6 is compatible with D16y8)
DOHC non-VTEC b series valvecovers will work on all DOHC non-VTEC B series head (ie: B18A will work on B18B)</TD></TR></TABLE>
Just curious, where does a "B18A" come from?
Old Aug 10, 2003 | 08:46 AM
hatchback's Avatar
Default Re: (hatchback)
Nevermind I found it, 2nd Gen 90-93 Integra GS.
backyardjoe
May 17, 2015 05:10 AM
B33FCAK3
Sep 2, 2008 01:09 AM
powerslide360
Oct 9, 2003 11:43 PM
team2n1hatch
Apr 1, 2003 06:11 PM
