Y8 head on a Z6 block
what for? is your z6 head bad? if not i wouldn't swap it as the z6 head flows better. get the y8 intake manni though as it flows better. if you head is bad and this is your replacement then you really just need to get a haynes or helms repair manual and follow the steps to remove it then just swap over all the sensors that the y8 head is missing, and install in reverse order. i think that with just the head swap you don't have to worry about the y8 head being obd2, but i could be wrong. anyone else know
this has been discussed ALOT lately and an answer still hasnt clearly came out which one is better. however the common answer and what i beleive is the y8 head has better low end and the z6 head has better top end. just the other day i bought and put on a z6 head on my y8 to see what it did and in fact pulls harder on the top end and pulls less on the low end. so i am keeping the z6 one on b/c i like top end over bottem end. hope this kinda helped
you will probly want to put the y8 distributor on too. the z6 one will not bolt up to the y8 head. if you buy a piece of crap y8 dist. for cheap you can change over ALL the internals so the wiring is correct and the dist. bolts up properly. the cap and rotor are even the same. just a tip for the swap
stealthcivic94
Dec 12, 2005 01:10 PM
