problem when vtec hits
Old Aug 9, 2003 | 11:55 AM
LSpimpTEC's Avatar
Default problem when vtec hits
when i hit vtec i can hear a little sputtering. i dont lose a lot of power but i can tell that its not kickin as hard. could it be the timing?(friend messed wit my timing) could it be a bad ecu program cuz i switched ecus wit my friend for awhile.
Old Aug 9, 2003 | 11:56 AM
Filliam H. Muffman's Avatar
Default Re: problem when vtec hits (LSpimpTEC)
what engine and what ecu are you using?
thats key bro
Old Aug 9, 2003 | 12:04 PM
LSpimpTEC's Avatar
Default Re: problem when vtec hits (JUN EK9)
well i think my name says what i run but LS/VTEC running chipped p28 right now... i usually run a p72 chipped but i switched because of rough idling
Old Aug 10, 2003 | 01:02 AM
LSpimpTEC's Avatar
jump
Old Aug 10, 2003 | 01:08 AM
Kamin's Avatar
chipped p28, chipped p72
that could mean anything.
what programs are on the ecu.
Old Aug 10, 2003 | 01:10 AM
LSpimpTEC's Avatar
Default Re: problem when vtec hits (Kamin)
hondata not real sure of the specs but it hasnt always done it so i think that its somethin other than ecu...but of course i could b wrong
Old Aug 10, 2003 | 01:13 AM
Kamin's Avatar
hondata is a little diffrent than a chipped ecu.
it could be the timing, but if its hondata i think you should go have it checked wherever you had it tuned origionally.
Old Aug 10, 2003 | 01:37 AM
LSpimpTEC's Avatar
damn ive had the reprogrammed ecu for so long i dont even remember who did it but ill figure that out. but without the proper tools to adjust the timing, do i just do trial and error? or am i screwed until i can get tuned?
SC61HB
Sep 17, 2007 09:00 PM
Chicano
Mar 18, 2007 12:07 PM
t1ny
Apr 19, 2006 08:55 AM
DarkTeg94
May 6, 2005 11:14 AM
X2BOARD
Apr 16, 2002 09:54 AM
