what is the MOST you can mill an h22 head, and how to calulate the increase in compression
Old Aug 9, 2003 | 08:18 AM
fastludeh22's Avatar
Default what is the MOST you can mill an h22 head, and how to calulate the increase in compression
ok first off i dont want to mill, but i have to. i miscalaulated ign timing w/n2o and detonated like hell.
it melted a decent spot between cyl. 1 & 2. i need to have it milled down, cause the head was just rebuilt w/full oversized ferria valvetrain.
i am going turbo so i dont want the compression any higher then it already is(9.7:1).
i was thinking i have 89 mm bore, so if i enlarge the cc to 89 mm that will drop the compression, but how much?
Old Aug 9, 2003 | 10:18 PM
Accord94DX's Avatar
Default Re: what is the MOST you can mill an h22 head, and how to calulate the increase in compression (fast
you want to increase the compression with a turbo??
wouldn't you want to drop it?
Old Aug 11, 2003 | 09:10 AM
flyrod's Avatar
running the same head with more displacement increases your static compression. I posted a thread a while back on milling the h22 head and resulting compression, search for it.
Too-R3ckl3ss
Apr 1, 2012 12:21 PM
Techna600f4i
Jun 19, 2006 11:49 PM
teamXteg
Apr 12, 2006 08:35 PM
Lewdin' Incognito
Jun 27, 2005 04:59 PM
DualKnuttz
Mar 13, 2003 09:18 PM
