Raybrig HID install
hey i just picked these up today
i open it up and all the instructions are in japanese. does anyone know how to install them? i have never installed hid's before. so i wouldnt know anything about it. is there anything special i need to know besides not to touch the bulbs? do the ballasts have to mounted away from anything?
thanks
thanks
nice! what are those rated at. i just got a set of philips 4300k for free from my buddy.....it was used for a week and then he took them off cause he wanted 5000k.
Host them on http://www.we-todd-did-racing.com - Thanks to Craig.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedik »</TD></TR><TR><TD CLASS="quote">i open it up and all the instructions are in japanese. does anyone know how to install them? i have never installed hid's before. so i wouldnt know anything about it. is there anything special i need to know besides not to touch the bulbs? do the ballasts have to mounted away from anything?
thanks </TD></TR></TABLE>
positive goes to positiv, neg goes neg, replace ur fuse, turn it on, u see no fire under the hood and u are set !!
it's easy to install, mine is just plug and play you cant go wrong.
or u can take some japanese course and read the instruction
it's easy to install, mine is just plug and play you cant go wrong.or u can take some japanese course and read the instruction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GettaluvR »</TD></TR><TR><TD CLASS="quote">
cool i kinda figured that part. but are there any special precautions i should know or worry about??..( i already know not to touch the bulbs) is there anything special about ballast placement? or wiring? i noticed that when all the harnesses are plugged together, 2 wires do not match up... i mean they are reversed .. instead of the green wire matching up with the other green wire it matches up to the yellow one and vice versa... btw pics will be up monday
</TD></TR></TABLE>cool i kinda figured that part. but are there any special precautions i should know or worry about??..( i already know not to touch the bulbs) is there anything special about ballast placement? or wiring? i noticed that when all the harnesses are plugged together, 2 wires do not match up... i mean they are reversed .. instead of the green wire matching up with the other green wire it matches up to the yellow one and vice versa... btw pics will be up monday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wiseguy »</TD></TR><TR><TD CLASS="quote">very nice!!!
where did you get them from?</TD></TR></TABLE>
got them from spw
got them from spw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GettaluvR »</TD></TR><TR><TD CLASS="quote">if it's fool proof then just plug them, make you u upgrade ur fuse to 15amp tho</TD></TR></TABLE>
um.. ok. which fuse and why do i need to do that?
um.. ok. which fuse and why do i need to do that?</TD></TR></TABLE>
... your sunroof fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">There are fuses underneath the driver side dash for the headlights. Upgrade to 15A. </TD></TR></TABLE>
ok ill do that
ok ill do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">send instructions to me...translation fee $50/page!
um...that would be quite expensive to translate all of them
</TD></TR></TABLE>um...that would be quite expensive to translate all of them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkGSR »</TD></TR><TR><TD CLASS="quote">
oh ok... will it make my sunroof open and close faster also??
</TD></TR></TABLE>oh ok... will it make my sunroof open and close faster also??
ur kidding right?
ur kidding right?
