motor stil dosen't idel
after putting a new head on my d16z6 the timing apears fine but the car still will not idel, it's getting spark gas, any ideas at would be wrong thanks in advance
Modified by flip b18b at 1:43 AM 8/11/2003
Modified by flip b18b at 1:44 AM 8/11/2003
any one have any ideas it's a d16z6 just replaced the head new plug/ wires firing ordor is correct just the car still has trouble starting and idels at like 100 rpm then dies please help
So the timing is good, and the engine gets spark/gas? As said above, maybe the throttle position sensor somehow got adjusted. Try adjusting it so the idle raises and see if that helps.
it's not gettin any cell's i'll check out the tps but it seems as if the car is allmost skipping
Modified by flip b18b at 12:36 PM 8/11/2003
