Stock Spring Question
Old Aug 8, 2003 | 06:12 PM
s13_240sx_92's Avatar
Default Stock Spring Question
Hey all, I have a 97 Civic Dx 4DR. I'm putting the stock springs back in. I need to know how to identify the front from the rear springs. I know one pair is heavier(sic?) than the other. Also one is more narrow, as in diameter.
I think I know which is which but need to confirm before I risk my fingers and body parts with that stupid cheap spring compressor I have. Thanks
Old Aug 8, 2003 | 06:38 PM
EG2 SiR's Avatar
Default Re: Stock Spring Question (s13_240sx_92)
Front = thick gauge shorter
back = thinner gauge and longer
Old Aug 8, 2003 | 07:11 PM
ek9mugen's Avatar
Default Re: Stock Spring Question (EG2 SiR)
front's are longer than the rears about 98% of the time
long and thick = FRONT
short and thin = REAR
Modified by ek9mugen at 4:47 AM 8/9/2003
Old Aug 8, 2003 | 07:24 PM
EG2 SiR's Avatar
Default Re: Stock Spring Question (ek9mugen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9mugen &raquo;</TD></TR><TR><TD CLASS="quote">
short and thin = REAR</TD></TR></TABLE>
long and thick = me
short and thin = you
hahahahahah
Old Aug 8, 2003 | 07:45 PM
so who is right here????
Old Aug 8, 2003 | 07:48 PM
EG2 SiR's Avatar
the front springs are definately of a thicker gauge.... as for the rear, they can be identified by this: The top of the rear coils is more tightly wound than the rest of the spring... The coils are closer together at the top...... That should help... I hope
Old Aug 8, 2003 | 07:50 PM
ek9mugen's Avatar
i was right woohoo
https://honda-tech.com/zerothread?id=566863
conformation or is it confirmation
Modified by ek9mugen at 5:06 AM 8/9/2003
Old Aug 8, 2003 | 07:57 PM
EG2 SiR's Avatar
in this case yes.... I was going by my set up. I have RS*R down springs... and the rear springs were longer..
Old Aug 8, 2003 | 08:07 PM
ek9mugen's Avatar
well in case of stock springs the fronts are longer and thicker
Old Aug 8, 2003 | 08:15 PM
EG2 SiR's Avatar
&lt;&lt;&lt;~~~~~admits to ownage..... Cant think:at work!
Old Aug 8, 2003 | 10:39 PM
Thanks Guys, I managed to figure it out.. If you apply some pressure on the springs the rear are softer, as in they compress easier than the fronts. So the fronts were a little bit longer, heavier, and the overall diameter was smaller. Not the diameter of the material its self but the entire spring. Now I got all these bump stops I don't know where each goes but thats not a big issue really right?
Old Aug 8, 2003 | 10:53 PM
ek9mugen's Avatar
the bumstops install with the fatter portion facing upwards like a V
92integraVTECgsr
Mar 26, 2008 10:55 AM
maynards_ek
Nov 17, 2007 12:37 PM
Redsun
Suspension & Brakes
May 10, 2006 04:20 PM
blkgsr03
10
Nov 23, 2003 04:54 PM
deepgreengsr
25
Aug 30, 2003 09:18 AM
