Loss of Drive while turning
This has been happening for a while, and eventually i just started ignoring it but it's started to get on my nerves.
when i take a turn, going at a moderate speed, i'll completely lose drive until I begin to straighten out the steering wheel. it's wierd, i can feel the car engaging when the steering wheel reaches a certain point.
it's not that bad, but if i take a turn fast and try to give the car gas while i'm turning i'll just rev the engine and not go anywhere, this behavior is a bit more serious cuz without any throttle input i run the risk of wiping out on a hard turn.
i've changed both my cv shafts, so i'm wondering if you guys have any idea what else it can be. the car is auto btw.
it's been a while since i changed it, but right when it started happening i put in new fluid and it didnt help. i guess it wouldnt hurt to change it again though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSH »</TD></TR><TR><TD CLASS="quote">are your tires losing traction when you do this?</TD></TR></TABLE>
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Did the problem start before or after replacing the axles?</TD></TR></TABLE>
Before, and replacing them yielded no difference.
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">Does it do it around right and left turns?</TD></TR></TABLE>
yup, more so in a certain direction, but i dont recall which.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">sounds like there is something wrong with the differental</TD></TR></TABLE>
that's kinda what i'm thinking.
Check your shifter cable. Maybe when you turn, some combination of flexy engine mounts with a slightly off cable adjustment, might be shifting into neutral?? At least this should be easy to check...
philkehn
Nov 19, 2008 03:12 AM
95bkeg
Dec 24, 2006 05:39 PM
