Current whp/ps with a B18C6
Old Aug 8, 2003 | 12:50 PM
Nerv2g's Avatar
Default Guys with a b18c6 was is your current whp or ps?
I'm just curious I have seen alot of dyno sheets for B18c5 but i'm wondering what numbers you guys are putting down. Also can you list your mods. Thanks
Old Aug 8, 2003 | 12:53 PM
92TypeR's Avatar
FSAE
Default Re: Guys with a b18c6 was is your current whp or ps? (Nerv2g)
Same as JDM B18C-R.
170whp is about average.
I'm disregarding the '98 spec JDM motor becasue of the 4-1 exhaust manifold. I've seen 176whp out of a stock '99 JDM ITR.
Old Aug 8, 2003 | 01:00 PM
Nerv2g's Avatar
Default Re: Guys with a b18c6 was is your current whp or ps? (92TypeR)
Cool I was really wondering because the compression and the final drive are the same as the B18C-R but they, b18c6's, came with the crapper USDM header, why you got me. I always wondered why they gave the JDM final drive to the EDM because of the autobahn I always figured they would have given them something closer to the LS gears.
Old Aug 8, 2003 | 01:06 PM
92TypeR's Avatar
FSAE
Comparing the motor to the '96 spec JDM ITR will be your best bet like I mentioned above. Almost identical besides the FD ratio. But your FD will not make any difference on the dyno.
I also wonder why the European market recieved the 4.785 final drive with such an emphasis on the autobahn.
Old Aug 8, 2003 | 06:09 PM
SurferX's Avatar
Probably because they figured a Type R doesn't have the power to go much faster than 140mph anyway. The 4.4 FD is the wimpy "Acura" ratio . The Honda Type R's got all the good stuff.
Old Aug 9, 2003 | 01:19 PM
RICHJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerv2g &raquo;</TD></TR><TR><TD CLASS="quote">b18c6's, came with the crapper USDM header </TD></TR></TABLE>
The EDM header is not the same as the USDM, IMO it is not even as good, although they have made an effort to make the primaries the same length they seem more restricted than the USDM ones I have seen pics off.
UKDM off of my car:-
Old Aug 9, 2003 | 03:08 PM
Spoond TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Same as JDM B18C-R.
I'm disregarding the '98 spec JDM motor becasue of the 4-1 exhaust manifold. I've seen 176whp out of a stock '99 JDM ITR.</TD></TR></TABLE>
THANK YOU Someone else that has witnessed a STOCK 98 spec JDM R with 175 WHP or better.
As for the FD the 98 spec JDM R has also different gearing from 3rd on so this evens out the top speed of the 96 spec and 98 spec.
Off the line 1, 2 gear the 98 spec has it. 3rd gear is the great equalizer and the 96 spec makes up ground. I can't seem to find the number right now but once I do I will post them the gearing of the tranny is different.
Old Aug 9, 2003 | 10:53 PM
92TypeR's Avatar
FSAE
Default Re: Guys with a b18c6 was is your current whp or ps? (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">THANK YOU Someone else that has witnessed a STOCK 98 spec JDM R with 175 WHP or better.</TD></TR></TABLE>
If my motor can put down 170whp stock, i'm sure .4 more in compression and a good exhaust manifold can net 6 more whp, if not more. I think the main problem is most of the '98 spec ITR's were not given a proper break-in period. It would be MY assumption, that 180whp is very possible.
The motor in question I saw was in a '97 hatch, but was completely stock besides the '99 JDM ITR swap, and using the corresponding ECU as well.
Crazy_1.8L
12
Feb 23, 2006 07:45 AM
akteamster
Oct 16, 2005 09:11 AM
sitinthehall
May 5, 2004 08:46 PM
SurferX
Jun 19, 2003 08:37 AM
AllMotorITR
Dec 12, 2001 05:47 AM
