Bad Clutch?
It's pretty normal there was a thread on this a day or two ago...
it's either the pedal assembly (spray it with wd40 or the like) or the clutch master cylinder... in which case you may need a new one... but more than likely it just needs a decent lubing... (I don't really recomend you take off your clutch master unless you feel comfortable doing so).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">its probably the clutch slave cyclinder.</TD></TR></TABLE>
if the sound is coming from the cabin, then the clutch pedal just needs to be lubed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
if the sound is coming from the cabin, then the clutch pedal just needs to be lubed.</TD></TR></TABLE>
Not if it's like mine... the master itself is squeeking... the pedal ***. just transfers the noise into the cabin...
And primo... did you mean clutch master?
maybe so maybe not...
it's internal squeeking from the master so if it is that then it may be more audible in the car because the pedal assembly tranfers the noise well...
I'd try to lube the pedal assembly then worry about the master if it's still squeeking.
LSEGHATCH
May 2, 2006 06:18 AM
geminis2k
Nov 20, 2003 11:33 AM
