slick psi gauge
i have a digital tire pressure gauge and a mechanical one. when i go the check my slicks with the digital one for example it will read 13.5 and the mechanical one will read 14 psi. which won is more accurate. what do you guys recommend i stick with using. what do you guys use.
Just fyi sometimes the mechanical ones become inaccurate.I used to work at a tire shop and I put 35psi all around,it went to the alignment rack and they read 45psi all around because my gauge was off.
im working this weekend that really sucks. what do you recommend i do so that i can get the right psi on my slicks for better traction. I really appreciate your help.
Start @ 12-psi, Now you let me know when you go to fontana, you do go to fontana right, if you do I will come up and help you get your best times. O by the way I do have a tire guage and it cost me $ 18.00 Good Luck John@M&H
ITR640
11
Mar 20, 2005 05:35 AM
nEoMuGen
13
Mar 26, 2002 06:50 AM
