lca bushing
Old Aug 8, 2003 | 12:36 AM
stockgreencivic's Avatar
Default lca bushing
Is there any way to get the LCA to shock busing out (on a civic)without a press?? i don't have a "real" torch to burn it out either,, and a propane torch doesn't get hot enough,, can anyone help me out?
Old Aug 8, 2003 | 02:09 AM
EG2 SiR's Avatar
Default Re: lca bushing (stockgreencivic)
I can help you get it out, but getting a new one in is a different story.... Start by using a drill to drill a hole in the rubber part (yes this is a ghetto, backyard racer tactic, but it works) once you have a hole, use a small knife as much of the rubber out as you can. Once that is done, use a hack saw to cut the outer ring of the bushing until you get to the metal of the LCA.... then use a chisel/scredriver and a hammer to knock the ring out.... It worked for me when I installed a prothane bushing into my motor mount!
ekhatchey
Nov 3, 2009 12:06 AM
aserenehope
Dec 7, 2006 02:27 PM
Trickturn
Suspension & Brakes
Oct 5, 2006 03:30 AM
TurboLSVtecTeg
Dec 2, 2003 08:23 AM
MyWhiteCivic
Aug 19, 2002 05:45 AM
