Will Accord springs fit on my car?
I just bought a pair of used Tein coilover springs. I picked them up cause they were dirt cheap. I'm using some crappy Weapon R coilovers right now. Could I swap these springs in either the front or back of my 90 CRX? The springs are 70mm.
btw they are 6kg non-tapered springs
This may be false information, but the spring rates for an accord and your car are going to be completely different, so when you put those on your car, it's going to make your car sit up much higher then it should(not enough weight to make the spring settle correctly). I think. Someone correct me if I am wrong. I just took a guess.
it probably won't fit either, and even if they do, the car will handle VERY poorly and probably sag or sit oddly.....My recommendation is sell them on eBay and get some that actually fit
Ok. It sounds like your desperate, but trying to make springs from another car fit is one thing, but then actually thinking about cutting them is another.
You know what, if it were me, I would save your money until you can find a nice spring/shock combo made specifically for your car. Good luck. Do not cut your springs. Ever!
jdmakkord88
Mar 21, 2009 07:03 PM
