Heat
Ive got a newb question, Ive always used 10w30 oil in my Z6, well I changed my oil and used 10w40 and it seems to run a little hot sometimes, the needle is just barely past halfway if I leave it sit in one spot, When I take off, it cools down to normal. As far as running I had some starter issues but got them resolved, it pulls hard all through the gears and runs nice. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsck3r »</TD></TR><TR><TD CLASS="quote"> Any ideas?</TD></TR></TABLE>
use 10w30 oil.
use 10w30 oil.
10-40 is thicker so it has more friction... sure it'll make it run a little hotter...
just switch back to what you should be using and don't vary from it till there's a problem with what you should be using (like burning oil... you'd go up a weight or two to try to prevent the oil from sneaking past the rings)... however this isn't always a good idea as parts that are meant to be lubricated may not be because the thicker oil will not fit in some tight places.
Okay thanks, thats what I thought but I wasnt quite sure, Im going to the salvage yard tommrow to get ecu connectors im going to see if I can get an integra radiator also!
