RSX Type R specs
The latest edition of Automobile magazine said the US RSX Type R will have 217 HP and 152 lb-ft of torque.
Just thought Id share
[Modified by HX_Guy, 12:02 PM 8/9/2001]
That is exactly the specs of the JDM Type R. I wonder if the USDM Type R is really going to meet those numbers since the JDM models are almost always tuned to be more HP. I suppose the JDM ITR might go up in HP during the same year.
Banned
From: PUT BACK MY AVATAR YOU FUCKING FAG MODERATORS, canada
sorry i havent been keeping up with the media but is the type-r for sure coming to north america? and when is the tentative release for it?
Although there was "just" a 25 HP (at the flywheel, even less at the wheels) increase between the 3G Integra GS-R and Type R, that was just one part of the R total package. You need to factor in the reduction in weight, LSD, stiffer chassis, tuned suspension, shorter gears, etc. etc. Add that to the fact that Honda didn't build the Type R to be a drag strip car.
The RSX Type S and Type R will probably be closer in performance than the 3G GS-R and Type R, but think the RSX Type R will hand the Type S it's *** on the track.
Here is some info I got from the Honda JP web page: http://www.honda.co.jp/factbook/auto...107/index.html
Weight:
2579 (No AC) 2601 (With AC)
Eng.:
217HP/8000RPM
152FT-LB/7000RPM
VTEC Comes on at 6000RPM
8400RPM Redline
11.5:1 CR
Trany:
1st 3.266 Same as RSX-S
2nd 2.130 Same as RSX-S
3rd 1.517 Same as RSX-S
4th 1.212
5th .972
6th .780
FD 4.764 (4.388 for RSX-S
Weight(WET): 117.3lb
10.4lb Flywheel
LSD
Tires:
215/45 R17
Check out the Honda page, it has cool pics.
Ermax
Weight:
Eng.:
217HP/8000RPM
152FT-LB/7000RPM
8400RPM Redline
11.5:1 CR
Trany:
4th 1.212
5th .972
6th .780
10.4lb Flywheel
LSD
Tires:
215/45 R17
Ermax
DC5_duty
Aug 29, 2006 01:43 PM
Michael Delaney
Sep 1, 2001 08:17 PM
iNteKra
Aug 26, 2001 02:22 PM
