SIR rotors with stock calipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I need a new name »</TD></TR><TR><TD CLASS="quote">SiR rotors are stock
Not in the US. I meant stock as in his stock STD rotors.....
</TD></TR></TABLE>Not in the US. I meant stock as in his stock STD rotors.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 »</TD></TR><TR><TD CLASS="quote">Use Si rotors and you'll be fine.
</TD></TR></TABLE> I belive you are wrong guy. I thought SIR brakes were the same as 90-91EX/90-93 integra size 10.3. Si rotors are smaller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote"> I belive you are wrong guy. I thought SIR brakes were the same as 90-91EX/90-93 integra size 10.3. Si rotors are smaller.</TD></TR></TABLE>
Yes I know the sizes but he has stock STD calipers, not SIR/Teg/Civic EX calipers, so why would he use SIR rotors with stock STD calipers?
I think your post confused some people. Most people post things like "Will the SiR rotor fit on my STD knuckles with STD calipers". That's not what you wrote. You want to know if "stock calipers work with the SIR hubs knuckles"
Well, your to answer your question it's "no". The SiR uses the same caliper as the EX sedan and possilby the Integra. Those are your choices. YOUR stock caliper is the STD caliper which I believe is the same caliper for the DX,LX, and Si as well. They won't fit over the larger rotor from the SiR. I'm not even sure if they would bolt up to your SiR knuckle.
Solution - go buy EX calipers from Pep Boys or AutoZone. Later on take back your STD calipers for the core charge. You don't want some crusty old used calipers.
EDIT - I don't know how long my site will be up because I canceled cable modem about 2 weeks ago, but here is what I did to do to make those SiR knuckles work on my Civic http://home.socal.rr.com/civic...x.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">I think your post confused some people. Most people post things like "Will the SiR rotor fit on my STD knuckles with STD calipers". That's not what you wrote. You want to know if "stock calipers work with the SIR hubs knuckles"
EDIT - I don't know how long my site will be up because I canceled cable modem about 2 weeks ago, but here is what I did to do to make those SiR knuckles work on my Civic http://home.socal.rr.com/civic...x.htm </TD></TR></TABLE>
Much better explained, thanks 4drEF, I knew I wasn't crazy! lol
KingHornet
Suspension & Brakes
Sep 17, 2006 04:58 AM
EGO
13
Dec 26, 2002 01:57 PM
