Pic of Carsound cat?
Old Aug 9, 2001 | 08:48 AM
01ITR#700's Avatar
Default Pic of Carsound cat?
Anybody have any good pics of the 94006 Carsound cat with the flanges and everything welded on, ready to bolt on? Looking for pics both off the car and installed. Thanks a lot.
Mark
Old Aug 9, 2001 | 08:59 AM
Jason's Avatar
Default Re: Pic of Carsound cat? (01ITR#700)
you've got mail
Old Aug 9, 2001 | 09:12 AM
SMSP's Avatar
From me too
Old Aug 9, 2001 | 09:16 AM
R-Rated's Avatar
Default Re: Pic of Carsound cat? (SMSP)
SMSP-Dave can you send me a pic also? I want to compare it to the 54006. Thanks
Old Aug 9, 2001 | 09:17 AM
MAIN727's Avatar
right here
theres more too
mike
Old Aug 9, 2001 | 09:23 AM
SMSP's Avatar
Default Re: Pic of Carsound cat? (R-Rated)
You got mail too feel free to post, the picture above I believe is of the 54006.
Old Aug 9, 2001 | 09:47 AM
01ITR#700's Avatar
Perfect, thanks a lot guys! Thanks for the emails also Mike and Jason. One other question, will the pictured cat above bolt on to a stock Type R? Or does it require any adapters, JDM 2½" collector etc? I plan on running stock USDM header, and B pipe TEMPORARILY with the Carsound cat and a Mugen Twin Loop Muffler. I have a good exhaust guy that can do any modifications for me real cheap so current or future modifications to the exhaust isn't an issue. I'll also Dyno the Exhaust setup as soon as I'm done if anyone is at all interested. I just got my baseline Dyno with no mods, so I can find out the real gains.
Thanks again.
Mark
Old Aug 9, 2001 | 09:54 AM
D's Avatar
D
94006 made by SMSP
D
Old Aug 9, 2001 | 10:42 AM
Rob Dizzle's Avatar
on the topic,
does a carsound cat bolt in to a system with a comptech 4-2-1 header and stock exhaust
would i just get the 2 1/4 inlet/outlet cat?
Old Aug 9, 2001 | 10:59 AM
SMSP's Avatar
Default Re: Pic of Carsound cat? (bob46802)
BOB46802 & 01itr0700,
If you are using a CompTech/DC/Greddy etc. 4-2-1 or stock they all have 2" collectors. You can't run the 94006 since the flare end of the cat would swallow the 2" donut. Burp. I use the 94005 (2-1/4") cat for these applications, it needs to be a little longer than the 94006 when used with a JDM type header, but it's not a problem. The cat outlet will be 2-1/4" ID so you can still have a mismatch depending on what exhaust you are running.
Thanks D for posting the pictures.
SMSP-Who says do away with all bottle necks.
[Modified by SMSP, 12:00 PM 8/9/2001]
Old Aug 9, 2001 | 11:57 AM
AssPenny's Avatar
From typer98
Craig
01 ITR
Old Aug 9, 2001 | 12:01 PM
FBP_1171's Avatar
Default Re: Pic of Carsound cat? (AssPenny)
Nice center piece for the living room
Old Aug 9, 2001 | 12:28 PM
Jason's Avatar
Default Re: Pic of Carsound cat? (FBP_1171)
not my pics, just had them on my hard drive....but I guess you could call it a conversation piece...
Old Aug 9, 2001 | 02:56 PM
Mike M's Avatar
Founding Member
Default Re: Pic of Carsound cat? (MAIN727)
right here
theres more too
mike
The model above is a 53006 for the JDM ITR B Pipe and 94-99 GSR
USDM ITR B pipe or 00-01 GSR and SI use the 94006 which is a longer body
Old Aug 9, 2001 | 08:12 PM
Nu2DaGame's Avatar
will the 94016 work with a jdm header?? And where can I get all correct flanges I need for the install??
Old Aug 9, 2001 | 09:17 PM
SMSP's Avatar
Default Re: Pic of Carsound cat? (Nu2DaGame)
Yes, the 94016 will work but why do you want to use a cat with an air tube if it's not needed? I can supply you with any parts you need to do it yourself.
Old Aug 10, 2001 | 08:34 AM
AssPenny's Avatar
Oh, looky what I just got in the mail. Its for a JDM header with a 2.5 collector to bolt up to the stock ITR exhaust... sweet
Thanks for the buy Mike, now all I need is for the header to arrive
Craig
01 ITR
Old Aug 10, 2001 | 09:09 AM
SMSP's Avatar
Now just get rid of your bottle neck.
Old Aug 10, 2001 | 12:19 PM
Toda Party's Avatar
Do carsound cats comply with emissions regulations? I mean i know they're cats but I think i've heard somewhere they're only marginally better interms of emissions than a test pipe...
Old Aug 10, 2001 | 02:59 PM
SMSP's Avatar
Default Re: Pic of Carsound cat? (NBP ITR 01-622)
They are made in CA and are EPA and CARB approved.
loner714
Mar 18, 2007 05:36 PM
KamikazeSol
Feb 23, 2004 04:10 AM
Hukd Up
Apr 2, 2003 05:51 PM
ShiftDown
Aug 6, 2002 02:36 PM
LuderCriS
Mar 15, 2002 04:44 AM
