Installing msd blaster ss coil
Old Aug 7, 2003 | 11:20 AM
killa_lude's Avatar
Default Installing msd blaster ss coil and mallory ignition box
i just bought a msd blaster ss coil and a mallory ignition box and i need to know what wires to use off of the stock coil harness, i noticed there was 3 : black/yellow, yellow, and blue. what is positive and what is negative, also what kind of ignition do preludes have so i can try to find the right wiring diagram in the mallory manual.
Old Aug 7, 2003 | 11:41 AM
Jagan'92's Avatar
Default Re: Installing msd blaster ss coil and mallory ignition box (killa_lude)
I'm not too sure about any of this, but here is a link to installing MSD 6 on a 5th gen. He says there's only one wiring difference b/w it and 4th gen.
http://www.hondaprelude.to/install_msd.html
Old Aug 7, 2003 | 03:58 PM
killa_lude's Avatar
Default Re: Installing msd blaster ss coil and mallory ignition box (Jagan'92)
alright i'll check it out
Old Aug 7, 2003 | 04:52 PM
SKDRCR's Avatar
the black/yellow and yellow both go to the positive side of your
coil and the blue goes to the negative
you might want to solder them though
i had one but it eventually went to ****, my car kept dying on the
highway,I put the stock one back on and presto
Old Aug 7, 2003 | 08:46 PM
killa_lude's Avatar
Default Re: Installing msd blaster ss coil and mallory ignition box (SKDRCR)
really?? why did it do that, did you have a ignition box?? maybe the stock ignition couldnt give enough power to the coil.
Old Aug 7, 2003 | 08:52 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">really?? why did it do that, did you have a ignition box?? maybe the stock ignition couldnt give enough power to the coil.</TD></TR></TABLE>
Explain ?
Old Aug 8, 2003 | 05:07 AM
Jagan'92's Avatar
doh you have a mallory ignition and i'm looking at a msd 6. anyhow - take a look at msd's site
http://www.msdignition.com/downld.htm
I'm looking at an MSD 6A and Blaster SS, just realized that is NOT what you have. Don't know about these Mallory ignitions, but they say it's the competition for the MSD 6A, so if you look at above URL and check out the MSD 6A it should all be the same. Specifically here: http://www.msdignition.com/pdf/pdf23.pdf
Old Aug 8, 2003 | 07:50 AM
killa_lude's Avatar
that diagram is for a internal coil. Preludes are external.
yeah i think generally its the same set up, the mallory has more wires though...thats whats screwing me up.
Old Aug 8, 2003 | 09:14 AM
Jagan'92's Avatar
Above, he says black/yellow and yellow is positive, blue is negative to the coil. I think in the original link I gave up top (MSD 6A install) the writer was calling the blue wire green. So he says that blue (or green) is the trigger input. I'm so confused. Will you do a write-up when you finish for us?
You may have found this wiring diagram already, but look at page 7:
http://www.92lude.com/prelude_...s.pdf
Old Aug 9, 2003 | 08:30 AM
killa_lude's Avatar
yes, i'll do a write up once we get both units working properly. but yes on my car the blue wire is the signal. i should have it done by the end of the day today.
ludeatomics
Mar 8, 2016 09:11 PM
smash fascism
Jul 5, 2005 04:26 AM
H22a4u
Jun 11, 2005 07:23 PM
juicedh22
Oct 9, 2004 05:45 AM
