i want to make my engine bay SUPER clean and uncluttered, what can move/remove???
Old Aug 7, 2003 | 08:15 AM
dingusjt's Avatar
Default i want to make my engine bay SUPER clean and uncluttered, what can move/remove???
alright i don't have ps or ac (i removed them) also my battery is in my trunk..
i've removed all my ac lines, condensor, evaporator and thats it.
i'm curious as to what else i can take out that is cluttering up my engine bay that may be related to these components...basically i want my engine bay to look like here is a good amount of open space in there...very clean and un cluttered.
also what can be taken out behind my radiator to make enough room for an intercooler??
Old Aug 7, 2003 | 08:40 AM
buzboy's Avatar
Default Re: i want to make my engine bay SUPER clean and uncluttered, what can move/remove??? (dingusjt)
Sounds like youve already taken out all you can. good work lad.
Old Aug 7, 2003 | 10:21 AM
shorty91's Avatar
every thing under your hood is there for a reason. i however removed my a/c as well
EF_LSVtec's Avatar
Maybe if you post a pic of your engine bay, peeps here can give a few suggestions...
Old Aug 7, 2003 | 10:23 AM
dingusjt's Avatar
Default Re: i want to make my engine bay SUPER clean and uncluttered, what can move/remove??? (EF_LSVtec)
good call i'll get something up here
Old Aug 7, 2003 | 10:45 AM
ThatRicerDaniel's Avatar
i feel what your tryin to do but in the 4thgen's its so hard to make a swap look really clean like you can in newer hondas.one small thing you can try is to rewrap your harness with new 3m tape so its tight, clean, and black. other than that i just try to keep everything clean and black. you can replace all the bolts visible in the engine bay including headlight, fender and raditor strap bolts with new shiny or anodized bolts. you can get the anodized from napa autoparts for cheap. make sure you have all the oem brackets and just try to keep the motor itself clean. good luck. cant wait to see those pics
Old Aug 7, 2003 | 11:28 AM
xci_ed6's Avatar
Default Re: i want to make my engine bay SUPER clean and uncluttered, what can move/remove??? (NitrousDreamz
you can get rid of the Evap system and charcoal canister.
-Dustin
Old Aug 7, 2003 | 12:18 PM
bagged89hatch's Avatar
how do you eliminate the evap system wont you get a cel if you unplug the wires
Old Aug 7, 2003 | 01:10 PM
CRX Spaz's Avatar
One more thing, if you don't use it, the window washer motor and tank. But this is already out of the way on the driver side up by the heaadlight and will not free up much space.
Torqueboxer
17
Oct 16, 2015 04:58 PM
kitsume
Mar 31, 2009 10:27 AM
trepteg
Mar 31, 2008 08:02 AM
Shakes
Mar 4, 2004 06:19 PM
" BRANDON HiCKS "
54
Oct 14, 2003 11:39 PM
