please help !!!
Old Aug 7, 2003 | 08:07 AM
integracivic94's Avatar
Default please help !!!
coming home from work and i can hear this tapping! i think it could the crank bearings and the top end is rattling aswell! can anyone please tell me how to adjust bits underneath the valve cover! Its a d16z6 do not have a helmes manual would be eternally grateful for any help!
Old Aug 7, 2003 | 08:13 AM
Default Re: please help !!! (integracivic94)
someone must know come on please fella's, need to sort it tonight to get to work 2moro!
Old Aug 7, 2003 | 08:34 AM
somebody put me out of my missery
Old Aug 7, 2003 | 08:46 AM
NonovUrbizniz's Avatar
Loved
it's
.18-.22mm (.007-.009in.) Intake
.23-.27mm (.009-.011in.) Exhaust
You HAVE to have the engine DEAD cold... UNDER 100 degrees F... NOT at or above...
those are the specs...
As far as procedure...
You start by putting the engine at #1 TDC... then you adjust those valves...
turn the crank 180 (cam moves 90) and do number 3 valves
turn the crank 180 (cam moves 90) and do number 4 valves
turn the crank 180 (cam moves 90) and do number 2 valves
Old Aug 7, 2003 | 08:47 AM
Loved
Default Re: please help !!! (NonovUrbizniz)
however if you SUDDENLY started to hear tapping and knocking chances are something went and an adjustment won't help...
but good luck.
JuggerNaut-CTR
Nov 4, 2012 05:54 PM
jdm_manny
Dec 1, 2009 07:35 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
zx2gotboost
19
Dec 17, 2005 10:27 AM
integracivic94
Aug 7, 2003 12:35 PM
