just got my ES sway bar bushing and bracket...
Old Aug 6, 2003 | 10:54 PM
mingchi69's Avatar
I to Smooch Pickle
Default just got my ES sway bar bushing and bracket...
it is suppose to be polyurethane rubber right?? but the 23mm rear sway bar bushing i got.. feels... no wait... it is pure solid plastic and feels like 0% rubber. It's a solid unit.. and doesnt feel like it will has any kind of rubber in it. If i were to use this bushing, to me, it would function the same as pretty much bolting the sway bar directly to the subframe.. since this bushing is solid plastic. anybody else have any other opinions on this. the bushing part number i got was from http://www.suspension.com part # 9-5127
Old Aug 6, 2003 | 11:00 PM
stolenhubcabs's Avatar
Default Re: just got my ES sway bar bushing and bracket... (mingchi69)
lol, sorry for the off-topic reply, but you have the same name as one of my friends, you're also from the dfw area too
Old Aug 6, 2003 | 11:17 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
polyurethane and rubber are 2 different things. The whole point of using poly bushings is that they are much stiffer than rubber, deflect less, and don't wear out since they are a synthetic material and not prone to deterioration like natural rubber is when exposed to the elements.
mingchi69's Avatar
I to Smooch Pickle
Default Re: just got my ES sway bar bushing and bracket... (stolenhubcabs)
hahah... my sn used to be mingchi96, but they banned me cause i was posting non-ITR stuf in the ITR forum, and then, i started being a dick. o well
Old Aug 6, 2003 | 11:18 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: just got my ES sway bar bushing and bracket... (PatrickGSR94)
i have had ES motor mount inserts, installed master kits from Energy suspension, and they all feel.... flexible... unlike these sway bar bushings, which i can almost certainly say it feels pretty damn much like solid black plastic. even sounds like it too..
Old Aug 7, 2003 | 11:29 AM
lustedp's Avatar
well, make sure you grease that stuff otherwise you will have squeeking problems.
I almost went with lca polyurethane bushings but was dissauded from doing so because of the nuissance issues that the individual i asked described to me.
If you're that worried about them then get the OEM rubber bushings, otherwise what's the problem?
Old Aug 11, 2003 | 04:01 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: (lustedp)
ehh.. will polyurethane sway bar bushings stiffen the ride??
JMZ400
Oct 17, 2018 11:47 AM
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
broketuner-Sol_Si
Suspension & Brakes
May 5, 2006 02:59 PM
JunY
34
Feb 9, 2006 04:43 PM
