Lightweight crank pulley
Old Aug 6, 2003 | 09:20 PM
MissMyHonda's Avatar
Default Lightweight crank pully
Ok, I've done all the free mods I can think of (A/C gone, PS gone, back seats gone, rear panels gone for the whole 1lb., spare tire) and I think I've run out of free mods I'm willing to live with not having...I hear a lightweight pulley helps, but also that it can cause damage....opinions, views, comments, places to buy, brands to buy please...I'd like a more educated voice than mine driving my decision if I should buy this or not (I also already have the bolt ons I/H/C/E/ECU)
Old Aug 6, 2003 | 09:39 PM
HYREV2NR's Avatar
Default Re: Lightweight crank pully (JoesTypeS)
The guys @ Unorthodox Racing said to keep thin oil (5/30) in the motor. They said heavy oil can cause the oil pump drive to shear off when it's cold outside cause the motor revs like a crotch rocket. Give it plenty of warm-up time. But thats what they said.
Old Aug 6, 2003 | 10:21 PM
TeamTooQuick's Avatar
Default Re: Lightweight crank pully (HYREV2NR)
Get a CTR N1 crank pulley, lightweight (2lb) single feed crank pulley, only runs alternator belt.....
Old Aug 6, 2003 | 10:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: Lightweight crank pully (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">Get a CTR N1 crank pulley, lightweight (2lb) single feed crank pulley, only runs alternator belt.....
If you're going CTR N1, you might as well go UR instead. Even the standard UR 3 belt pulley weighs less than the N1, and it underdrives slightly too.
Old Aug 6, 2003 | 10:36 PM
Default Re: Lightweight crank pully (Padawan)
The UR is lighter then 2lbs? If it was me i would still go with the N1, and the N1 costs about 1/2 as less compared to the UR.
I would like to see where it shows the weight of the UR because I never heard it weighs less then two pounds with the 2 other belt spots....
Old Aug 6, 2003 | 10:55 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">The UR is lighter then 2lbs?</TD></TR></TABLE>
Yep. Its aluminum, not heavy steel.
The 3 rib UR pulley weighs a hair less than the CTR SINGLE RIB, and the UR single rib pulley
weighs A LOT less.
I would get the UR over the CTR anyday.
Old Aug 7, 2003 | 02:00 AM
SloCivicHMM's Avatar
Default Re: Lightweight crank pully (sgT)
If this helps I got my UR pulley installed this week....feels great! revs alot quicker, I too heard about the problems called UR and they said to keep oil in there and to make sure it don't run low, and that they stock pulley is balanced and just have a rubber piece for vibration not balancing....that the UR isblanced just a stock.
I've never heard of the thin oil...I run 10/30 cuz I have a zc that runs hot so a lil thicker oil will work better....wonder if thats an issue??
Old Aug 7, 2003 | 04:05 AM
my main question is about the harmonic balance and that i've heard it can make your bearings get fucked up...
Modified by JoesTypeS at 10:14 AM 4/26/2005
Old Aug 7, 2003 | 04:11 AM
sgT's Avatar
sgT
Default Re: (JoesTypeS)
rings? no.
everyone claims bearings get ruined.
I have yet to see direct evidence of this, and I use the UO crank pulley.
Old Aug 7, 2003 | 04:45 AM
skribblah's Avatar
Default Re: (sgT)
Originally Posted by theoldone.com
Date: 19-Jul-99 10:40 PM
Author: Primodreams
Subject: would a little piece crackedoff crank pulley cause vibrabtion under accc?? help~
Date: 21-Jul-99 08:15 AM
Author: Jewone
Subject: RE: i've heard good and bad about underdrive.. it might blow you oil pump no?
I have AEM underdrive pulleys, I like them.. I have a friend that also has the unorthodox pulleys and they are just as nice... neither of us have had any problems.. I have had mine close to 2 months.. anyone else here about the problem with the oil pump...
Date: 21-Jul-99 10:59 AM
Author: RacerX
With all the people I know that use underdrive pulleys, the only problem I have heard of is that if you have a really high power stereo, you may not be making enough charge with the UD pulleys to push the system really hard since the alternator is spinning slower also. Some companies have gotten around this by making pulleys that reduce drag on everything else, but keep the alternator spinning at the proper speed, I don't know of any import companies that have done this yet though. As to the oil pump exploding, it sounds like a fat load of crap.
RX
Date: 21-Jul-99 03:00 PM
Author: NITRO
Subject: RE: A Real Crock
As the oil pump on a Honda is driven by the crankshaft (and there are NO belts involved), how could you blow the oil pump? Underdrive pulleys will slow down the alternator, A/C, and power steering pump which may produce a touch more power at the flywheel / wheels, but the speed of the oil pump is not changed any at all. The pump is internal and it's rpm is entirely governed by the crankshaft rpm so there's no way that you can change it with external mounted belt drives. Now, if any of you are running external dry sump oil pumps, the pulley ratios could have a BIG effect on the pumps ability to provide necessary oil flow. I doubt that there are many guys running external belt driven pumps, especially since a good system will cost as much as building the entire engine.
Date: 21-Jul-99 10:55 PM
Author: Primodreams
Subject: yeah.. but .. what about vibration from the UD pulley...
i heard that honda crank pulleys' are counterbalanced or something where if removed... the rotating assembly will have vibrations and thats what caused oil pumps to blow out...ie.. comptech racings' type R.. blue out and oil pump with a UD racing pulley. .. i was just wondering...
Date: 22-Jul-99 10:48 AM
Author: TOO
Subject: Mr. Primodreams,A Question Of Balance
Bad Vibrations
I'll post a more complete rendition of this on the too site shortly, but let me begin by saying that it's good to be back and I'm only here to expressly address some questions that need some "good" answers. I am not here to provide schedules or any information regarding the blower program. The topic is that of aftermarket crank pulleys. Let me begin by saying that we have always called the pulley on the accessory drive end on the Honda cranks Harmonic Balancers. People never seemed to understand what we were talking about and so the word "pulley" was frequently used to avoid confusion. If you look carefully at a Honda "pulley", you'll find that it's not a single piece of metal. Typically, there's a nodular iron or steel hub and another "ring" of iron or steel surrounding it containing the belt grooves. The two parts are joined by a rubber layer, which is highly compressed and sandwiched between them. Why rubber? If you notice, many four cylinder engines over the years have used counter rotating shafts to help make the engine "feel" smoother. Reciprocating internal combustion engines and especially in-line four cylinder versions, all produce shock pulses, which are very apparent to the occupants of the car. Every engine produces a shock pulse each time an individual cylinder fires. So, in the case of the four cylinder variety, there are four large individual pulses for each 720 degrees of crank rotation. Each time there's a pulse, it causes the internal components to do a rapid acceleration-deceleration event. When you consider the mass of all the internal components and visualize all these parts stopping and starting during their reciprocating and rotating motions, the additional stress "spikes" tend to make it all the more reason for one to wonder how any of it can work for any length of time. The harmonic balancer is made with the rubber coupling so that, when the individual "spikes" occur, the inner portion may move with the crank, but the rubber connected outer ring's mass helps prevent the hub and crank from going as far or as fast during the spikes or pulses. Remember that the outer part had considerable mass, so it tends to want to stay in motion at the speed that it's traveling and that's why it can prevent excessive harsh motion by the crank and other internal parts. To put it simply, the harmonic balancer is a shock absorber for the engine and thus prevents the individual pulses from destroying everything in the engine. A quick bit of history; Back in the late '70's, all the Pro Stock engines had been reduced in displacement to allow the cars to weigh less. At that time the vehicle weight was based on engine "type" and total displacement. Typically, the engines were in the 330 cubic inch range and running 10,000 to 11,000 rpm was normal, especially in high gear at the traps. There began to be a lot of engines that were "exploding" their harmonic balancers on the big end. Aside from cutting the steering in half and blowing the front tires, large hunks were also finding their way into the grandstands and there were numerous injuries, many of which ended in death. NHRA immediately mandated that solid "balancers" were to be used from that point on. Keep in mind that a balancer can't be solid and function properly, but the rules were the rules. Moroso and a couple other companies who were tight with NHRA began making aluminum billet "balancers" immediately and everyone bought them so they'd be legal to race. All of a sudden, racers were getting only 10 passes from their crankshafts, which had previously lasted an entire season. Initially, most people thought the cranks were "bad", but after destroying engine after engine, a few knowledgeable engine people figured out where the problem actually was coming from and several companies that were capable of making functioning harmonic balancers sprang up over night. They are all still in the business to this day and their units are actually much better than the factory units of years before, as they are made from premium materials and optimized for high rpm applications. With this short bit of history finished, I'll begin to wind it up by stating what we do with the Honda engines. If the balancer has more belt grooves than the application needs, i.e. the power steering pulley, we machine it off. When it comes to the the pulleys that are actually a part of the outer portion of the balancer, we leave them intact. This procedure will not lighten the unbalanced hub substantialy, but the outer balancer ring will keep all its mass and function correctly. I also need to say that a large driven mass such as a blower or alternator, can have a slight dampening effect, but to actually work properly, the belt connecting the components to the crank would need to be 4" to 5" wide and the belt tension would be so great that it would wear out the number 1 main bearing as well as the bearings of the the driven parts in short order. It's especially important to keep the balancer "as is", if you're running an aluminum flywheel. The reduction in flywheel mass can also increase the pulsation shock strength and a higher level of vibration will immediately be observable. So if you lighten the flywheel,it's absolutely more necessary than ever to maintain the mass or the harmonic balancer. I realize that there's a lot of hype out there where manufacturers are promising this and that. The oversize crank pulleys can drive other geared or belted components faster due to the diameter ratio increase, but if you're deleting the balancer in the process, the short and long term side effects are going to hinge on your decisions. Larger diameter pulleys for the alternator, power steering and any other belt driven accessory are good ways to slow the speeds and drag of the those components, but when doing a large diameter crank pulley, the larger pulleys should actually be designed to fit "over" the stock balancer. Perhaps, someone will begin to make some good quality "functional" balancers some day, but until they do, you need to proceed carefully, as some good looks and minimal power gains can be off set by a ruined engine. I'm sure that there will be some fall out regarding what I'm saying here and to that effect I need to remind everyone that we do not manufacture hubs, big pulleys, or harmonic balancers for Hondas and none of what I've said is the least bit politically motivated.
And yes, any engine with a non-functional hub or balancer can ruin the crank driven oil pump and a whole lot more.
………………………….T.O.O. ………………………
Date: 22-Jul-99 12:00 PM
Author: RacerX
Subject: RE: Mr. Primodreams,A Question Of Balance
Since it is now stated that we need some kind of harmonic balancer to keep everything together, would it be possible to use whatever size pulley (solid undampened unit) and attach something like a Fluidamper to that pulley? Would that allow you to run whatever you wanted without fear of unnecessary wear? Or do I have the fluidamper concept wrong, is it just like the stock unit, with the belt riding on it, only with a different dampening system?
RacerX
Date: 22-Jul-99 04:06 PM
Author: TOO
The Fluidamper is an excellent product that's used by quite a number of first class engine builders. In order to work correctly, it needs to be keyed and bolted to your crank, just as the stocker. We frequently drive pumps, and alternators from pulleys that bolt to the inner hub attached to the crank, but I'd think that sticking a lot of mass out beyond the crank snout could be a recipe for trouble, due to the increased distance to the #1 main bearing. We have made some larger diameter pulleys for Hondas that slip over the originals and are held in place with several allen set screws. Perhaps this revalation will "affect" some aftermarket manufacturers to make some this way. It's really simple to do. ........T.O.O. ..............
Old Aug 7, 2003 | 05:18 AM
sgT's Avatar
sgT
Default Re: (skribblah)
I cant believe you quoted that crap.
Old Aug 7, 2003 | 05:45 AM
Todd00's Avatar
I said I don't want a title!
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">I cant believe you quoted that crap.
lol. Although I'm shocked that it has actually been over 4 months or more since I have seen reference to the TOO thread in one of these all-to-common UR discussions.
I've actually met and spoken with the owner of UR and this particular thread was discussed. We even talked about the one that circulates on the BMW page.
Old Aug 7, 2003 | 05:49 AM
And what'd he say...
Old Aug 7, 2003 | 05:59 AM
sgT's Avatar
sgT
Default Re: (George Knighton)
My car has 125k miles on it, most of which was with the pulley.
longest single motor to run in the car was 65k miles. no bearing wear whatsoever.
Many other cars with pullies as well.
George, acura still claims that honda parts dont interchange. They can kiss my ***.
Old Aug 7, 2003 | 06:03 AM
b19coupe's Avatar
Default Re: (sgT)
I have heard that lightened pulleys have two negative effects.
#1-accelerated bearing wear.
#2-oil pump failure.
Have seen neither firsthand.
My question-do the benefits outweigh the risks?
Old Aug 7, 2003 | 06:04 AM
sgT's Avatar
sgT
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">My question-do the benefits outweigh the risks?
as far as im concerned there is no risk.
Old Aug 7, 2003 | 06:18 AM
The fact that sgT is saying there is no effect and so many people put stock in what he does, makes we want to go w/ the UR Race pulley...
Old Aug 7, 2003 | 07:49 AM
I don't know why people dont want to go with the N1 if they already have their P/S and A/C out. Its a stock JDM part that has no risks or had any horror story's told on it. The N1 already weighs 2lbs who cares about the other pound or however much. I heard from a lot of people(acura specialists) that if you have a car that revs past 7000rpm's and don't have a harmonic balance it will cause one of those "risk's" to happen......
Old Aug 7, 2003 | 08:44 AM
MK Ultra's Avatar
I've been using a cheap, aluminium crank pulley for the last 5 years.
Two and a half years ago I damaged it when trying to remove it from the crank to replace the timing belt. There's a big, fat chunk missing (we're talking 70 degrees worth) from the rib closest to the motor. If indeed it ever was balanced it surely isn't now.
I've put well over 20,000 miles on the car with the pulley this way. My motor hasn't blown up yet.
Old Aug 7, 2003 | 08:52 AM
Padawan's Avatar
Darth ModerVader
Default Re: (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why people dont want to go with the N1 if they already have their P/S and A/C out. Its a stock JDM part that has no risks or had any horror story's told on it. The N1 already weighs 2lbs who cares about the other pound or however much. I heard from a lot of people(acura specialists) that if you have a car that revs past 7000rpm's and don't have a harmonic balance it will cause one of those "risk's" to happen...... </TD></TR></TABLE>
The CTR N1 pulley is a solid piece, and as such, it carries just as much "risk" as any of the Unorthodox pulleys. "Stock JDM" or not, there is <U>no</U> dampener on the CTR N1 pulley. As for why people would want to go with the UR over the N1, the reasons have already been stated - it's lighter and it underdrives.
Old Aug 7, 2003 | 10:37 AM
Default Re: (Padawan)
I heard that with UR and other aftermarket crank pullies its a good idea to upgrade the oil pump since the motor is reving alot faster!! anyone agree or have an opinion on this??
Old Aug 7, 2003 | 04:14 PM
sgT's Avatar
sgT
Default Re: (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">I heard that with UR and other aftermarket crank pullies its a good idea to upgrade the oil pump since the motor is reving alot faster!! anyone agree or have an opinion on this??</TD></TR></TABLE>
no need
Old Aug 7, 2003 | 04:25 PM
BudMan's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">My car has 125k miles on it, most of which was with the pulley.
Many other cars with pullies as well.</TD></TR></TABLE>
Steve - I'll back you on this one...I'm up to 108,000 miles. All 3 UR pullies put on at ~25,000. No problems yet & this motor has never been opened up. Daily driven until last month & go to several road course events each year.
UR works just fine
**NOTE: how's the clutch hanging in there?
Old Aug 7, 2003 | 04:28 PM
STOLEN - ITR 98-0652's Avatar
55,600+ miles with Unorthodox Pulley... driving the sh*t out of it... and no problems.
Don't believe the hype. Like Steve said, "no risk".
Old Aug 7, 2003 | 04:58 PM
sgT's Avatar
sgT
Default Re: (BudMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">
**NOTE: how's the clutch hanging in there? </TD></TR></TABLE>
We'll see how long this tilton lasts. But I have faith...
After all, its twice as much as other clutch kits out there
