Rattle noise from underneath the car.
Hey guys.
Jus a few days ago I noticed a rattlin noise from the header back.
I do not know exactly what caused this to rattle but it sounds metal to metal and it's not extremely loud but it can be heard in the cockpit. It also goes away and comes back. Another thing I've noticed was my exhaust is shaking a lot when I view it from the back, I have a DC Sports stainless steel cat back connected to a straight test pipe connected to a JDM CTR header.
I jacked my ride up and started to poke some pipes around but everything is stiff as a boner. But when I kick my exhaust tip I can hear the rattle from somewhere towards the middle/front of the car.
Has this happened to anyone else? Anyone else have the same exhaust system with any problems?
Im guessing it's just the hangers someplace and I can get it welded at any muffler shop, what do you guys think?
Thanks
Thanks
It may be your catalytic converter cover, it is rattling on our accord right now and it's pretty loud and annoying at times. It's an automatic so it isn't the shifter in my case, maybe in yours too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK99civicEX »</TD></TR><TR><TD CLASS="quote">It may be your catalytic converter cover, </TD></TR></TABLE>
i wasthinking cat, but he said he had a testpipe (cat replacement)
Yes, yes I do have a short shifter, but I've had it for a long time and I think it may be the exhaust itself.
I dont have any heat shields or a cat.
When I kick my exhaust I can hear the little rattle, and my exhaust is pretty loose.
Im jus wondering if anyone has the DC Sports stainless steel system with the same problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 »</TD></TR><TR><TD CLASS="quote"> Im guessing it's just the hangers someplace and I can get it welded at any muffler shop, what do you guys think?
Thanks
Well at this point, I think you really need to get a good look underneath your car for yourself. So... take it to a shop and have them take it up on their lift. Be there underneath the lift with the tech and see what it is for yourself and take it from there. Those sorts of inspections are usually free.
Even on an oil change, I am always walking around underneath my car and checking everything out (carefully).
Thanks
</TD></TR></TABLE>Well at this point, I think you really need to get a good look underneath your car for yourself. So... take it to a shop and have them take it up on their lift. Be there underneath the lift with the tech and see what it is for yourself and take it from there. Those sorts of inspections are usually free.
back when i put my header on i totally forgot to put my stock donut gasket from the stock, so that could be it.... its the little round gasket that's at the end of the downpipe...
Well fortunately for you, it's a simple exterior rattle and it shouldn't be anything mysterious or complicated to fix. Direct observation is the best in this case. I know that I'm not psychic. lol
So what are you sayin, you're Miss Cleo?
But seriously I think I'll jus go to someplace and see what is exactly makin the noise.... hope it doesnt cost much, and hopefully they wont rat on me to the smog people
it may be ur shifter, when u hear the noise grab ur shifter really tight if it stops then it has sumthin to do with the shifter, otherwise, id say ur exhaust bolts r loose, i had a rattle like that, and next thing i new my exhaust was draggin on the floor, id suggest u go down there and try and tighten all the bolts, also maybe ur o2 sensor is loose, that can cause a rattle
Juan_Mitosis
16
Oct 14, 2009 04:49 PM
