car wont idal right revs to 2000 rpm then drops to 1000 rpm..help
Old Aug 6, 2003 | 06:14 PM
import_racer_ky's Avatar
Default car wont idal right revs to 2000 rpm then drops to 1000 rpm..help
my car is revving up to 2000 rpm then frops to 1000 rpm keeps doing it over and over i already did this
check for vac. leaks
change map senser
also you can hear air sucking hard throw the intake
Old Aug 6, 2003 | 06:16 PM
Loveless's Avatar
Default Re: car wont idal right revs to 2000 rpm then drops to 1000 rpm..help (import_racer_ky)
I had similar problem, it's my iacv (idle air control valve). I suggest you find a friend with an integra and use his. If the problem persist then that's not the problem but chances are, it's your iacv
Old Aug 6, 2003 | 09:32 PM
squad801's Avatar
Default Re: car wont idal right revs to 2000 rpm then drops to 1000 rpm..help (Loveless)
if you take of the throttle body there is a screw that you will tighten It will stop the idle problem. Also if you let it idle till it is at operating temp this might help I had the same problem. if that doesnt help check the resistor box.
Old Aug 6, 2003 | 11:56 PM
G2hybrid's Avatar
what resistor box? i have a friend who has the same problem on his 97 gsr.
Old Aug 7, 2003 | 12:07 AM
4DooRGiSzer's Avatar
Default Re: (G2hybrid)
a friend of mine had the same problem, turned out to be his intake manifold gasket. once that was replaced it went back to normal. and his car runs perfect. that was on an F22B in a 1992 Honda Prelude. its some kind of JDM accord motor or something.
Old Aug 7, 2003 | 02:56 AM
LSvtec03's Avatar
also check the fast idle thermo valve. that was my problem
aznromeo4u
Apr 2, 2018 09:21 AM
clean3two3
Oct 24, 2007 02:19 PM
del soler
Sep 10, 2004 02:06 PM
stRtypR25
Jan 12, 2003 03:09 PM
