How to check ecu CODES after obd 0 - obd 1 conversioin?
Old Aug 6, 2003 | 05:11 PM
gocivicgo's Avatar
Default How to check ecu CODES after obd 0 - obd 1 conversioin?
How do you do it without that funny litrtle plug??
Or is there a way to make that plug??...and hook it up to a little light somewhere?
Old Aug 6, 2003 | 06:14 PM
tdaccord's Avatar
Default Re: How to check ecu CODES after obd 0 - obd 1 conversioin? (gocivicgo)
there is a wire that you just need to ground. once you ground the proper wire, the check engine light will start blinkin the code(s) for you
Old Aug 6, 2003 | 07:51 PM
gocivicgo's Avatar
Default Re: How to check ecu CODES after obd 0 - obd 1 conversioin? (tdaccord)
Do you happen to know which wire?
Old Aug 11, 2003 | 03:43 PM
greenmachinex's Avatar
i probably sound retarded but what are the ecu codes everyone talks about
DSRxSALSA
Jun 14, 2010 08:20 PM
94whitegsi
Aug 4, 2006 07:22 PM
yoshio006
May 22, 2005 06:49 PM
HamiltonRex
Nov 14, 2004 03:46 PM
c8r9x
Aug 9, 2003 12:16 PM
