A Case of Transmission Mis-identity...
Old Aug 6, 2003 | 03:15 PM
juicedh22's Avatar
Default A Case of Transmission Mis-identity...
So I bought a used transmission (from someone on this site) The tranny was supposedly a jdm h22 transmission, but the kid wasnt sure, and the bar label w/ the tranny code was torn off (stolen?? I dunno?) So anyways, I get the transmission installed, and it is def. not an h22 tranny, the acceleration is very sluggish, I THINK its an f22 tranny, but not sure, does 2700 rpm's at 70mph sound right for f22 tranny ??
All I know is this acceleration sucks, I want my h22 tranny back
Old Aug 6, 2003 | 03:16 PM
preluda92's Avatar
Default Re: A Case of Transmission Mis-identity... (juicedh22)
Sounds like a Pelude S tranny to me!
Old Aug 6, 2003 | 03:47 PM
MiddSchoolRacr's Avatar
do H22's and H23s got the same tranny?!?!
Old Aug 6, 2003 | 04:18 PM
TravisEK's Avatar
Default Re: A Case of Transmission Mis-identity... (J B G)
John, he said he wanted an H22 tranny. He probably doesn't want a non-working H23 tranny. In fact, probably nobody wants that.
Old Aug 6, 2003 | 04:30 PM
TravisEK's Avatar
Hmm, so some guy took a transmission out of his car because it had a "slight" grind. And exactly how do you know it works?
Old Aug 6, 2003 | 04:54 PM
juicedh22's Avatar
Default Re: A Case of Transmission Mis-identity... (TravisEK)
Umm, what are you guys talking about... I took out my stock h22 tranny because 2nd, 3rd, and 5th gear syncrhos were fucked, and I completely trashed the 5th/rev gear pack. buying a used tranny for 400 bucks was a lot cheaper than rebuilding or buying a remanned one.....
the One I got works fine, the guy told me he bought the jdm motor swap for his h23 prelude, and was going to keep the h23 tranny so he didnt need the jdm h22 one(which really turns out to be an f22 tranny)
Old Aug 6, 2003 | 08:16 PM
soon2Baluder's Avatar
not to change the subject or anything but... does anyone know if the s2000 tranny is interchangable with an h22 h23 motor. i knownothing about s2k's but the fact that it is a 6spd and that to me is more apealing than a lude 5spd.
Old Aug 6, 2003 | 10:00 PM
Qfactor's Avatar
Default Re: (soon2Baluder)
here's the quick way when buying a used transmission that doesn't have the label to identify them from what car it came from. on the clutch case where fork boot is at outside there is a stamp number only the H22 transmission will have the P16 stamped on the case non H22's such as H23,F22 will have the PX5 stamped on them. so if there's a person selling an H22 JDM/USDM tranny make sure it's a P16 clutch case (bellhousing). here's the H22 stamp
and the f22,h23
Modified by Qfactor at 7:37 PM 8/8/2003
Old Aug 7, 2003 | 04:56 PM
juicedh22's Avatar
Default Re: (Qfactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">here's the quick way when buying used transmission that don't have the label to identify the from what car it came from. on the clutch case where fork boot is at outside there is a stamp number only the H22 transmission will have the P16 stamped on the case non H22's such as H23,F22 will have the P15 stamped on them. so if there's a person selling an H22 JDM/USDM tranny make sure it's a P16 clutch case (bellhousing).
[img]www.imagestation.com/album/?id=4291837295&p=4248245288&idx=37[/img]
go here:http://www.imagestation.com/album/?i...8245288&idx=37
sorry tried posting picture here but don't know how to just yet</TD></TR></TABLE>
Thanks Qfactor, thats a great help to help those who havent been scammed, I wish I would have talked to you/found out before I bought this transmission...
Modified by juicedh22 at 5:10 PM 8/8/2003
Old Aug 7, 2003 | 05:20 PM
spoolinlude's Avatar
I live under a rock
Default Re: (jz)
prolly a f22....... i put one in my car to help out with launching... the taller gears make it a lot quicker........(if you have the power to pull the gear!!! otherwise you're slower than hell!!!!!!) but yeah 70 at 3000 sounds about right, its way up there
Old Aug 7, 2003 | 05:38 PM
juicedh22's Avatar
Default Re: (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">prolly a f22....... i put one in my car to help out with launching... the taller gears make it a lot quicker........(if you have the power to pull the gear!!! otherwise you're slower than hell!!!!!!) but yeah 70 at 3000 sounds about right, its way up there</TD></TR></TABLE>
you think so? I think my acc. is a lot slower, not as noticable in 1st and 2nd, but it starts catching up. As for power... I make 212 to the ground, dunno if you turbo boys consider that powerful or not...
Old Aug 8, 2003 | 10:34 AM
TravisEK's Avatar
we're talking about the tranny J B G was trying to sell.
Old Aug 8, 2003 | 06:24 PM
I live under a rock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">if you have the power to pull the gear!!! </TD></TR></TABLE>
did you miss that part......... power to pull gear meaning at least upwards of 315-325..... i make (well made) well over that so i thought the f22 trans was great
Old Aug 11, 2003 | 12:43 PM
juicedh22's Avatar
did you miss that part......... power to pull gear meaning at least upwards of 315-325..... i make (well made) well over that so i thought the f22 trans was great</TD></TR></TABLE>
No i didnt miss that part
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicedh22 &raquo;</TD></TR><TR><TD CLASS="quote">
... I make 212 to the ground, dunno if you turbo boys consider that powerful or not...</TD></TR></TABLE>
but if your saying I need 300hp, then I guess I dont have enough But oh well, I still hit about 140 in 4th gear.
Old Aug 11, 2003 | 01:37 PM
I live under a rock
Default Re: (juicedh22)
yeah...... thats a wierd feeling isn't it
Old Aug 11, 2003 | 02:37 PM
skunk2lude01's Avatar
good luck finding a s-spec. I have been looking for a while and when a prelude sir tranny pops up its always the type-s with atts.
Old Aug 11, 2003 | 05:40 PM
crj_lll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisEK &raquo;</TD></TR><TR><TD CLASS="quote">John, he said he wanted an H22 tranny. He probably doesn't want a non-working H23 tranny. In fact, probably nobody wants that.</TD></TR></TABLE>
Who is John and what type of non-working tranny does he have. I am looking for one to build a custom transmission.
Old Aug 12, 2003 | 10:29 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2Baluder &raquo;</TD></TR><TR><TD CLASS="quote">not to change the subject or anything but... does anyone know if the s2000 tranny is interchangable with an h22 h23 motor. i knownothing about s2k's but the fact that it is a 6spd and that to me is more apealing than a lude 5spd. </TD></TR></TABLE>
NO it wont work. the s2000 is also rear wheel drive
rico892002
Aug 18, 2009 04:01 PM
spoonhatchblack
Mar 22, 2004 07:49 AM
juicedh22
Aug 6, 2003 08:37 PM
