help with cel code
Old Aug 6, 2003 | 02:40 PM
projectEK9's Avatar
Default help with cel code
I took out my oem intake pipe a while ago, and the cel light happened to pop on, thinking this was the sensor that hooked onto the pipe, I didnt think much of it....I just installed a cai on my car, and when I unhooked the battery to reset the ecu, the light went off....then came back on......my friend told me about checking the code by myself...which i did....the light blinked once..... meaning...."Open or short in O2 sensor circuit, defective Primary O2 sensor" WHAT DOES THIS MEAN? Do i need a new o2 sensor? Im open to all comments and suggestion...thanks guys....
Old Aug 7, 2003 | 04:35 AM
JimBlake's Avatar
Default Re: help with cel code (projectEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectEK9 &raquo;</TD></TR><TR><TD CLASS="quote">..."Open or short in O2 sensor circuit, defective Primary O2 sensor"...</TD></TR></TABLE>
That's what it means...
First, you check the circuit - look for busted wires or worn-off insulation. Use a DMM to make sure the wiring has continuity back to the ECM.
If there's nothing wrong with the circuit, then get a new sensor.
Old Aug 7, 2003 | 09:44 AM
projectEK9's Avatar
Default Re: help with cel code (JimBlake)
would this sensor be the one at the catalytic converter? im pretty sure it is...primary right? THANKS
Old Aug 7, 2003 | 10:21 AM
mmuller's Avatar
Mad Scientist
primary is the first one
Old Aug 16, 2003 | 03:41 PM
projectEK9's Avatar
Default Re: help with cel code (mmuller)
just installed a new sensor.....cel code stayed on after resetting the ECU/ dc the battery.....what do I do now? all the wires look good......I dont want to take it to the dealership and for them to diagnose it and tell me its the same problem....any sugguestions?
Old Aug 16, 2003 | 03:47 PM
pip9's Avatar
which o2 sensor did u replace?
Old Aug 16, 2003 | 03:48 PM
projectEK9's Avatar
Default Re: help with cel code (pip9)
primary one.....
Old Aug 17, 2003 | 04:27 PM
projectEK9's Avatar
my idle is going crazy....i dont have a tach on there right now, but my car died 4 times today because it was idling too low....man....whats going on? Does anybody know how much a primary o2 sensor would cost at the dealership?
Old Aug 18, 2003 | 04:29 AM
JimBlake's Avatar
You just put a new one on there, so it shouldn't be that. Unless you managed to fry it somehow. Did you use a universal one where you had to splice wires? Check all the wiring with a DMM, don't just look at them.
Old Aug 18, 2003 | 08:27 AM
projectEK9's Avatar
what exactoy is a DMM and what does it do
Old Aug 18, 2003 | 09:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectEK9 &raquo;</TD></TR><TR><TD CLASS="quote">what exactoy is a DMM and what does it do</TD></TR></TABLE>Digital multi-meter. Volt-meter, ohm-meter, continuity-tester, etc...
A wire can have insulation worn thru when it goes thru the firewall, or it could be broken somewhere you can't see. I actually had a wire broken inside the insulation once.
You can check each circuit for continuity or shorts to ground, you can check ground wires to make sure they're grounded, tedious stuff like that. If replacing the sensor itself didn't fix the problem, then it must have been in the wiring.
RST10
Oct 8, 2013 10:02 AM
Mr.Speed
Feb 21, 2006 08:15 PM
Koyoloeor
Oct 13, 2005 04:57 PM
terminaloverlowd
10
Jul 27, 2004 03:12 PM
projectEK9
12
Aug 18, 2003 03:49 PM
