skunk2s - need some quick help before install
Old Aug 6, 2003 | 12:48 PM
tegasaurus's Avatar
Default skunk2s - need some quick help before install
The numbers on them are as follows:
0700.0250.010S
0700.0250.010S
0700.0250.008S
0700.0250.008S
They 10s are the fronts and the 8s the rears... correct? that's 10 kg/cm or whatever and 8 kg/cm thus making 500f and 400r or 400f and 300r?
blah
-Ryan
Old Aug 6, 2003 | 04:19 PM
skunkintegra's Avatar
Default Re: skunk2s - need some quick help before install (tegasaurus)
pretty sure its 500f and 400r
edit--ur right... higher spring rate up front.
Modified by skunkintegra at 8:58 AM 8/7/2003
Old Aug 7, 2003 | 02:30 AM
tegasaurus's Avatar
Default Re: skunk2s - need some quick help before install (skunkintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure its 400f and 500r
http://www.9krpm.com/9krpm_flash/store_skunk2.html </TD></TR></TABLE>
hrm.. bump
Old Aug 7, 2003 | 09:30 AM
roydogg's Avatar
Why would the rear be 500 and front be 400. I'm pretty sure it's the other way around cause the extra 100 pounds is needed in the front to compensate for the weight of the motor. Well my skunk2's are 500 all around and that is stiff as ****. I thank god I took them off ASAP.
Old Aug 7, 2003 | 09:57 AM
JDM2ndGen's Avatar
Default Re: skunk2s - need some quick help before install (roydogg)
are you talking about springs or coilovers?
Old Aug 7, 2003 | 10:05 AM
no2unenolife's Avatar
500f 400r
rmiles87
Oct 7, 2005 05:40 AM
GokuSs4
Jun 23, 2005 01:38 PM
Armaan
Apr 7, 2005 05:43 PM
vinuneuro
Mar 4, 2004 04:20 AM
