EG brake problem
ok, i can pull up to a stoplight and hold the brake, then the pedle goes lower and lower until i pump it. where should i start to check. this only happens when idling at a stop light. when the pedle gets to the floor i have no braking abilities at all until i pump them.
im having the same problem, i have to pump mine up before i start my car.......i think it has something to do with the MC......mine gets really bad when its hot outside, i have to put my parking brake on when im on a hill. it sucks i don't have money to fix it yet
over time the seals inside the master cylinder piston, wear out and allow fluid to leak around them. this is an internal passage of fluid. you wont see a leak. you need to replace themaster cylinder and belld the system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">over time the seals inside the master cylinder piston, wear out and allow fluid to leak around them. this is an internal passage of fluid. you wont see a leak. you need to replace themaster cylinder and belld the system.</TD></TR></TABLE>
yeah what he said. bad M/C
goto autozone, get a master cylinder, i got mine for like $30 after the core charge of like $40. Your gonna need some brake fluid for the bleed, and some plastic tubing like you would use on fish tanks, for the air... then like a empty bottle or bucket to empty the bleed into.
Do a search here for "brake bleeding" thats how i was able to do mine.
But seriously.. my car did the same thing, and it was my master cylinder.
kENNy
kENNy
like they said, it sounds like your master cylinder is going out, especially if the fluid is filled, that happened to me before. you have to kinda stick your foot under the brake pedal to lift it, so you can brake...that sucks...just swap out the MC, make sure the brakes are bled properly, and you should be fine
