injectors???
Old Aug 6, 2003 | 11:06 AM
oday's Avatar
Default injectors???
Can anyone explain the different kinds of injectors, what each are good for and how they work differently. Peak and hold.........???????
Old Aug 6, 2003 | 02:10 PM
Rocket's Avatar
Default Re: injectors??? (oday)
INJECTOR IMPEDENCE(dynamic electrical resistance)
There's Peak and Hold which require more currrent v. Saturated. Running Peak and Hold injectors with an ecu made for saturated injectors may burn out the ecu.
NOZZLE TYPE
Pintle
This is probably the most common nozzle style and produces a cone shaped spray pattern similiar to what you would see with the vegetable misters at the produce section of your supermarket. Brands that have this type if nozzle are, kihein (Honda OE), Denso (Toyota, etc), and Bosch.
Disc
Lucas injectors use the disc nozzle. This makes for a laser beam style squirt pattern. This injector is commonly sold by RC Engineering in there 245, 270, 310, 370, 440, and 550cc/min injectors.
Ball Disc
The ball disc injector uses a dis with very small holes in front of a metal ball. This type of nozzle provides extremely good fuel atomization and can idle extremely well even in 1000cc sizes. The brand that his this type of nozzle is Rochester.
Hope this helps.
doodooheadfart
Feb 22, 2007 09:53 PM
PyroVTEC
Jun 27, 2003 12:59 PM
MidoriEK4
Mar 2, 2003 02:53 PM
b20b
Feb 5, 2002 09:14 PM
