Changing Oil Pan Gasket...
From: In the heart of the ghetto of the, Suburbs NYC
First attempt in changing it...is it straight forward or a b!tch to change. When i attempted the mail oil seals, i was in for a shocker..is this going to be the same...
any hints/tips/guidance...thx
Havn't looked at it yet...but i'm sure it's not as easy as "taking pan off changing gasket"..haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybridAccord »</TD></TR><TR><TD CLASS="quote">but i'm sure it's not as easy as "taking pan off changing gasket"..haha</TD></TR></TABLE>
thats all it was for me. the engine was out of the car though but that shouldnt make much of a difference.
You have to take off the exhaust downpipe to get enough clearance to remove the pan. If you can get the downpipe off, you should be golden for everything else.
Spray the **** out of the bolts with PB Blaster, and let it sit overnight. If they're really bad, you may have to use some heat to get them out. Use a big *** breaker bar if possible. You're going to need leverage.
Edit: 93AccordEx, the downpipe makes a world of difference unfortunately
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StimpyBoy »</TD></TR><TR><TD CLASS="quote">
What he said...
The downpipe needs to be unbolted and pulled out to make some room...
</TD></TR></TABLE>What he said...
youstolemybeer
Nov 6, 2016 10:27 AM
trooper0641
14
Oct 11, 2005 07:11 PM
crxtremes
11
Oct 17, 2002 01:19 PM
