Spark Plug Question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">tried searching?</TD></TR></TABLE>
I did a search
thanks
I did a search
thanks
Well...I only said that because this very same question gets asked about once a week. I'm not trying to be a dick, honestly.
OH here I'll even help
NGK
BKR6E-11
Pretty much stock B16A
NGK
BKR6E-11
What's your app?
I like Autolites and NGK. I've found Bosch to suck *** on motors I've tried.
Also: I've found that projected tip plugs like the NGK PFR and ZFR series don't work as well as the BKR or BCP series or Autolite 392X series. For really high dome pistons, you'll wanna run retracted plugs like NGK R5671-A7 or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">Just recentley switched to NGK BKR6E-11's.</TD></TR></TABLE>
That's what I use too. I switch every few oil changes... Their so damn cheap it's worth it. Before this, i had denso iridiums, no different than my $4 NGK's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">What's your app?
Also: I've found that projected tip plugs like the NGK PFR and ZFR series don't work as well as the BKR or BCP series or Autolite 392X series. For really high dome pistons, you'll wanna run retracted plugs like NGK R5671-A7 or so.</TD></TR></TABLE>
I have a b18c5 with 11.1 comp
Cams: Skunk Stage 2
Exhaust: 2.5
Intake: Custom Iceman Short
Header:JDM
Fpr,Vafc,Chipped P28,
I have been runnig Bosch 4227 for about year and half with no problems.
So what does everyone think I should run
Thanks Marc P
Cams: Skunk Stage 2
Exhaust: 2.5
Header:JDM
Thanks Marc P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">Go with something like a BKR6 or BCPR6. It should run much better than the bosch.</TD></TR></TABLE>
I can attest to that. I switched from Bosh Platinum 2s to BKR6 and damn the car runs sooo much better now.
i should have my autolites from rocket this week, look forward on see if there is a but dyno differance with these.
i also track my gas milage, so we'll see if that changes.
hopefully it will just make the cars power delivery smoother.
