88 suspension
Old Aug 6, 2003 | 03:32 AM
dc2_and_ef's Avatar
Default 88 suspension
ive heard two things at felt only one, ive heard on here that t he rear end is not so desirable (iv felt it kinda twichy, like its about to break loose), and when I called a salvage yard to get prices of lca's the said that its basically the same as a type r, does anybody have before and after comments of doing this swap
Old Aug 6, 2003 | 04:13 AM
Timmah!!'s Avatar
Default Re: 88 suspension (dc2_and_ef)
What you are talking about is pasive rear stearing, and yes the 88 model CRXs have it. I love it, but if you modify it, you have to make sure what you are getting is for the 88. I dont know if you can use stock or aftermarket ITR stuff on the rear of our cars or not. I think, if you want to, you can replace the LCA and shocks and whatnot, with 89-91.
Old Aug 6, 2003 | 10:03 AM
CRXRageD's Avatar
Default Re: 88 suspension (azroth)
Yes you can use ITR rear shocks and also the LCAs are identical.
Old Aug 6, 2003 | 10:56 AM
EL Vap133's Avatar
If you don't like the 88 rear LCAs, you can replace them with the 89-91 LCAs, but don't forget to get new shocks as well...
Old Aug 6, 2003 | 02:31 PM
travis's Avatar
Default Re: 88 suspension (Vap133)
I think the negative press about the 88 suspension came from problems that the average Joe was having with the car feeling twitchy. When I was hunting for a road race car, I specifically wanted the 88 because of the rear suspension. I wouldn't change it for anything, including the rear drums
Old Aug 6, 2003 | 04:20 PM
Wiz's Avatar
Wiz
Default Re: 88 suspension (travis)
aye the twitchyness grows on you
so its confirmed I can go with the rear ITR shocks
has anyone done this, changed to the rear ITR shocks and does anyone know of any adjustable ones
but yes, I too would not give up my 88 rear suspension
Old Aug 6, 2003 | 04:57 PM
EL Vap133's Avatar
Default Re: 88 suspension (Wiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wiz &raquo;</TD></TR><TR><TD CLASS="quote">aye the twitchyness grows on you
but yes, I too would not give up my 88 rear suspension </TD></TR></TABLE>
The shocks are exactly the same from rear 88 CRX to rear ITR shocks...
Old Aug 6, 2003 | 05:01 PM
SuperCivic's Avatar
i can confirm that they are also used on the jdm SiR w/ rear discs. i can also confirm that 89-91 LCAs are a direct replacement.
Old Aug 6, 2003 | 05:23 PM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
The shocks are exactly the same from rear 88 CRX to rear ITR shocks... </TD></TR></TABLE>
Yup, in fact all 88 Civic's and CRX's have the ITR style rear LCA. And yes as someone stated, the reason they were ditched after 88 was because the average consumer didn't like the way it felt (too "twitchy" and stiff) I personally wouldn't change it to 89-91 style and don't plan to ever do that to my 88.
Old Aug 6, 2003 | 06:28 PM
don_tot's Avatar
Having built an SCCA ITA CRX Si, '88 CRXs are the most desireable cars because of low weight and the rear suspension. Changing the LCA doesn't affect handling; it's the geometry of the upper control arm movement that makes the difference. If you change over to the '89-91 style LCA, you'll still feel the same 'twitchiness'. You merely open your options to more shock interchangeability.
silver_racer
Feb 18, 2009 09:40 PM
89hatcher
Nov 21, 2008 08:33 AM
Vince_badaz
17
Jan 31, 2003 07:58 AM
allmotor.net
Jan 17, 2003 04:19 PM
x James Bond x
Aug 22, 2002 03:25 AM
