burning fuel and low idling
My car idles below 600 rpms at times. Sometimes the idle will dip down really low after I take my foot off of the gas. I replaced my timing belt at around 90k. I have about 126k on it now. Does this have anthing to do with the timing? I also seem to keep on losing motor oil after a week or two of driving. I don't see any leaks, so is my car burning oil...? and could this be associated with the timing belt / or water pump (which I replaced at the same time)? I also add coolant to the resevoir, and it goes all the way back down really fast. Is this normal? Any thoughts or ideas would be greatly appreciated.
i hope you find out... my car does the same idling problem, at a complete stop after i let go of the gas... the rpms drop very low then come back up to normal idle rpms... and my car's horrible on gas. hope someone knows why.
