Front end pull
Old Aug 6, 2003 | 02:59 AM
firehawk456's Avatar
Default Front end pull
I have an Accord that pulls to which ever side of the rode I am on but mostly to the right . The dealer and Honda Rep. both has told me that this is normal. I can't believe that Honda would not at least try to fix the problem. I have talked to two other front end specialist that has told me that it is a matter of setting the caster for the front wheels but that Accord does not have a simple way to do this. My question is, does anyone know of this problem and what have they done about it?
Is there a Honda dealer out there that really knows what he is doing when it comes to front end problems?
Old Aug 6, 2003 | 07:22 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Front end pull (firehawk456)
Wouldnt a wheel alignment and balacing of tires, fix this problem?
Old Aug 6, 2003 | 04:59 PM
Default Re: Front end pull (-Bionic-)
What does wheel balancing have to do with the front end pulling to the right??
Old Aug 6, 2003 | 05:14 PM
CaptainObvious's Avatar
Mine does the same thing. It is really annoying. Im too cheap to get an alignment and hope that is the case. But if that is the solution someone say for sure.
Old Aug 6, 2003 | 05:27 PM
bill-71SS's Avatar
I have been a honda tech now for 28yrs. I have never seen so many pulling problems on accords and ody.vans as I have in the past 2 years. You are right about honda saying it is normal.Thay just released a service bulliten that says a lane change in 6 secs.or more is a normal condition,under 6 secs. is a problem,most cases will drift to the other lane in approx. 8-12 seconds,which in muy opinion is a problem,but not to honda. Find a good front end tech and have them shim the front bars to correct the caster. good luck.
Old Aug 6, 2003 | 05:32 PM
Default Re: Front end pull (CaptainObvious)
From what I know and what I have been told by those I trust in the auto repair industry, a front end alignment will not solve the problem on the '03 Accord. The problem lies with there being no way to set the caster on the front wheels.
Old Aug 6, 2003 | 05:36 PM
Default Re: Front end pull (bill-71SS)
Again, from what I have been told, the front end does not have the adjustment that it needs to solve the problem especially on the caster. Mine will start to change lanes as soon as I let go of the wheel and be in the next lane in about 3-5 seconds. Very annoying on long trips.
Old Aug 6, 2003 | 05:39 PM
bill-71SS's Avatar
on the ody. van,we have to actually shift the sub frame to change the caster for it to stop pulling,I have not done an 03 acc. yet, but I will check one out at the shop tommorrow and get back to you.
Old Aug 6, 2003 | 05:40 PM
bill-71SS's Avatar
by the way, who is the honda rep over there, I work at a fla. dealer and might know him.
Old Aug 6, 2003 | 05:43 PM
I got his card here someplace and will get it to you ASAP.
I would appreciate all the help I can get.
Old Aug 6, 2003 | 05:45 PM
David Cathcart, District Parts & Service Manager
danlkb1
Honda Civic (2006 - 2015)
Oct 27, 2015 08:58 AM
DIsco1378
Jul 3, 2009 08:58 PM
rota power
Dec 10, 2005 08:48 PM
DSpaul
Jul 3, 2004 02:57 PM
