Looking for a good exhaust cut out.
Old Aug 5, 2003 | 07:03 PM
racinskittle's Avatar
Default Looking for a good exhaust cut out.
I really dont wanna go under the car in order to remove it or put it back on.
Are there any cheaper options?
Any opinions on what to get? Im not sure what Im looking for.
What are you guys running?
Running a D16Z6 turbo. I saw the Jegs one which looked good for a good price, but is there anything i dont have to remove from under the car?
LMK
Thanks
Dan
Old Aug 5, 2003 | 07:12 PM
swrdply400mrelay's Avatar
Default Re: Looking for a good exhaust cut out. (racinskittle)
Get an electric cutout
http://www.quicktimeperformance.com
Or Arospeed makes a mechanical one.
http://www.arospeed.com
Old Aug 5, 2003 | 08:08 PM
How safe is this to run on stock exhaust? Can I run stock while boosted and then open it up when I push it?
Old Aug 10, 2003 | 02:30 PM
tek_civic's Avatar
its plenty safe, its just like running an open dp. if you have a boost controller then i would turn it down to minimum setting as the increased exhaust flow may make you boost a little more. it will REALLY help your turbo spool up time.
Old Aug 10, 2003 | 02:47 PM
Default Re: Looking for a good exhaust cut out. (tek_civic)
cool, thanks. I got the 3" for my D. Hope it's not overkill.
Old Aug 10, 2003 | 03:26 PM
tek_civic's Avatar
cool, let me know how it turns out! you might need to pick up some reducers because you might not have a 3" dp, if its smaller then you just might need the reducers to make it work, but performance shouldn't be affected too much.
Old Aug 10, 2003 | 03:27 PM
evoeone's Avatar
summit
27$ i use it on my VW, works liek a charm
skrigz
Mar 17, 2006 07:38 PM
mitsuman
Apr 9, 2004 02:34 PM
Dengar
11
Jun 11, 2003 06:07 AM
01ITR#700
Sep 5, 2002 12:27 PM
glagola1
May 23, 2002 01:29 PM
