Preference on tranny fluid?
Old Aug 5, 2003 | 06:45 PM
egizzle8
Guest
Posts: n/a
Default Preference on tranny fluid?
Anybody have any preference on tranny fluid i.e, redline, mobil 1, honda oem? My wife went to autorice and they gave here motor oil and said that's what the computer said to use? I've used mobil 1 and my 88 si tranny is crap after about 2k. Any suggestion, I'm up for any.
Old Aug 5, 2003 | 06:50 PM
FourthGenHatch's Avatar
Default Re: Preference on tranny fluid? (88boostedzcrx)
HONDA OEM!
Old Aug 5, 2003 | 06:55 PM
insomniac791's Avatar
Mobil 1 synthetic is bad for honda trannys. I was told by my mechanic and the dealership to use either valvoline 10w-30 motor oil or honda mtf. Honda MTF got rid of my friends 3rd gear grind. I have also heard that GM Syncromesh is good but I never used it myself.
hope this helps
later
Matt
Old Aug 5, 2003 | 07:14 PM
KevronsEG's Avatar
Default Re: (insomniac791)
GM yes GM syncro mesh
Old Aug 5, 2003 | 08:27 PM
Ef Whore's Avatar
Default Re: (CIV616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIV616 &raquo;</TD></TR><TR><TD CLASS="quote">GM yes GM syncro mesh</TD></TR></TABLE>
Yeah I know it's a GM product, but that shiz works wonders....try it part#12345349.
Old Aug 5, 2003 | 10:55 PM
guttedEF's Avatar
I second that. I use the GM Synchromesh part#12345349 in my JDM YS1 w/ LSD and it works wonders. Fixed my LSD chatter and my 3rd and 5th gear grinds. I tried everything in it from 80w-90 gear oil, to Honda MTF to regular 10w-30 motor oil. Nothing comes close to the GM Synchromesh. Period.
Old Aug 6, 2003 | 04:34 AM
keithv's Avatar
Default Re: (guttedEF)
redline shockproof lightweight...but only b/c i run a quaife...
Old Aug 6, 2003 | 07:13 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guttedEF &raquo;</TD></TR><TR><TD CLASS="quote">I second that. I use the GM Synchromesh part#12345349 in my JDM YS1 w/ LSD and it works wonders. Fixed my LSD chatter and my 3rd and 5th gear grinds. I tried everything in it from 80w-90 gear oil, to Honda MTF to regular 10w-30 motor oil. Nothing comes close to the GM Synchromesh. Period. </TD></TR></TABLE>
Yeah you gave me the idea like a month ago!
Old Aug 6, 2003 | 09:45 AM
RCautoworks's Avatar
How much does a bottle of that cost ? And how many does it usually takes to fill up a trans ?
Old Aug 6, 2003 | 09:53 AM
CRX Si's Avatar
Default Re: (90blackcrx)
I have redline in mine with no problems, but my tranny didnt grind in the first place... My buddy Chris (incubus) also used redline in his B16 tranny and it helped a little bit but it still grinds from time to time as far as i know...
Old Aug 6, 2003 | 10:48 AM
keithv's Avatar
Default Re: (CRX Si)
the normal redline is not that good for honda trannies. the shockproof is much better!
Old Aug 6, 2003 | 10:49 AM
ScottEK's Avatar
Default Re: (keithv)
I always use Honda MTF... but if my tranny started to grind at all that stuff would be out of there and I'd fill back up with GM Syncromesh.
Old Aug 6, 2003 | 11:06 AM
NathanMorris's Avatar
Default Re: (beta13)
The GM stuff is wonderful! go for it.
Old Aug 6, 2003 | 11:15 AM
EFSiR's Avatar
I've taken a number for trannies apart. Stick with OEM honda MTF.
Old Aug 6, 2003 | 12:08 PM
BAZ's Avatar
BAZ
can I pick up the GM syncromesh at autozone, pep-boys, etc. or should I just pick it up from a dealer.
Old Aug 6, 2003 | 12:57 PM
NVMYSi's Avatar
Default Re: Preference on tranny fluid? (BAZ)
GM dealer, cost me around $11 a quart. buy three, your trans will take 2.5 quarts. It works, don't understand it but almost eliminated my 3rd gear grind (still have it if I drive really hard).
Old Aug 6, 2003 | 01:08 PM
BAZ's Avatar
BAZ
Default Re: Preference on tranny fluid? (NVMYSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVMYSi &raquo;</TD></TR><TR><TD CLASS="quote">GM dealer, cost me around $11 a quart. buy three, your trans will take 2.5 quarts. It works, don't understand it but almost eliminated my 3rd gear grind (still have it if I drive really hard).</TD></TR></TABLE>
SWEET, Im definately gonna check this stuff out.
I guess GM is good for at least one thing
Old Aug 6, 2003 | 02:18 PM
egizzle8
Guest
Posts: n/a
Damn mad post on the tranny fluid post. Thanks everyone. I think I'll give the GM stuff a try.
Old Aug 6, 2003 | 03:15 PM
R6Boy69's Avatar
Cant go wrong with HONDA MTF. It was meant to be there.
Old Aug 6, 2003 | 03:23 PM
Ef Whore's Avatar
Default Re: Preference on tranny fluid? (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">I've taken a number for trannies apart. Stick with OEM honda MTF.
So have I....what does you taking trannies apart have to do with Synchromesh? I always was like"Honda MTF nothing else" until this stuff STOPPED my grind, and it shifts incredibly smooth.
Old Aug 6, 2003 | 03:59 PM
NVMYSi's Avatar
Default Re: Preference on tranny fluid? (crXBoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">Cant go wrong with HONDA MTF. It was meant to be there.</TD></TR></TABLE>
Nope, 10W30 is the recomended OEM replacement. Honda MTF was meant for new Honda's
Old Aug 6, 2003 | 07:29 PM
VTgringo's Avatar
Nope, 10W30 is the recomended OEM replacement. Honda MTF was meant for new Honda's</TD></TR></TABLE>
it was only recommened in the manuals because honda didn't have there own brand when the ef's came out. there have been great advances in technology since 88-91
Old Aug 6, 2003 | 07:30 PM
Ef Whore's Avatar
Default Re: Preference on tranny fluid? (VTgringo)
Actually the EF's manual says 10w30/5w30 . BTW that fluid has been around for a good 10+ years.
Old Aug 6, 2003 | 07:42 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Preference on tranny fluid? (Ef *****)
GM stuff huh, its about as expensive as the Honda MTF.... bump cause I like to hear feedback....
Blaze
Old Aug 6, 2003 | 07:46 PM
Ef Whore's Avatar
Default Re: Preference on tranny fluid? (Blaze45)
It's $11/qt. from "Goodwrench"
