SS braided fuel lines and Earls fittings. Pic.
No Big Whoop
I am almost done, all I need to do is connect the fuel cell to the lines, secure the cell, and plug the pump.
I am also installing a roll cage so I had to do that first before installing the cell. What a job that was.
More later
More later
btw... is that a 4-1 header your runnin? just curious if your runnin into any clearance issues w/ the 4-1 on 1.8 block? gonna be runnin similar setup, i hope i can fit the 4-1 in there without hitting crossmember. i should be ok, i have the jimfab traction bars. thanks.
I dont see a pic??
*EDIT* NM now its there??!! Looks good man!! I wouls also like to see more pics and some of your whole car!!
It would be great to see some of the pics of your fuel cell. BTW your setup looks real nice, and very profesional.
No Big Whoop
I really don't know the part numbers.
You can get the fittings from Summit, jegs, etc. I used An-8 for supply and An-6 for return. Here a couple extra shots. the fuel cell is not secured yet, so the straps are not centered. BTW, this is not a kit. you need to buy the fittings one at a time and SS braided hose made specially for this type of aluminum fitting.
looks great - bring it by titan sometime - would love to take a closer look at that setup, been thinking of doing something like that on one of my cars for a while now
james
james
-Can the AEM fuel rail work with a B&M fpr?
-how much did the fitting cost you?
-how did you do that earls fitting onto your valve cover?
- " sam " do that to your IM vacume line?
- in that pix is it with a stock fuel rail? did you have to use a banjo fitting at the returne line where it bolts on to the rail?
-what kind of meter/gauge is that?
-is that also a banjo fitting on the Fuel filter?
slwazgsr
Oct 28, 2002 08:29 AM
