B16B pistons w/ Crane 2 cams ??????
Old Aug 5, 2003 | 04:19 PM
jdmjopey's Avatar
Default B16B pistons w/ Crane 2 cams ??????
I"m wondering if anyone here is running a higher compression C5 with crane stage 2 cams....i'm trying to tune it myself the best that i can, and i'm wondering if anyone has had any good luck with adjusting their cam gears......thanks
Old Aug 5, 2003 | 04:44 PM
Eric R's Avatar
Default Re: B16B pistons w/ Crane 2 cams ?????? (havsom)
I don't think you'll have too many asnwers in this forum about crane cams.
Most members here are more devote of Toda, Jun, Spoon, and once in a while, Skunk2.
Hours in dyno sessions are a most when tuning, not a matter of luck!
Old Aug 5, 2003 | 05:03 PM
92TypeR's Avatar
FSAE
Cam gear tuning will be car to car anyways. Hondas aren't very consistant with gear tuning. As mentioned before, go to the dyno and spend hours tuning, that will be the only sure answer.
If you are concerned about valve/piston clearance, I wouldn't know.
Old Aug 10, 2003 | 09:41 PM
phantoman's Avatar
Default Re: B16B pistons w/ Crane 2 cams ?????? (92TypeR)
i have ctrs in my gsr block, type r head.
i had the crane 2 in my car.
i yeilded a 178 and 125tq with them.
that is only with a vafc. timing was at 16 degrees,
vtec was at 6k rpm.
i did not have any luck with cam gears,
IMPATIENT
Sep 18, 2007 03:50 AM
Redsun
Aug 30, 2004 06:23 AM
DanishR
Apr 6, 2004 10:37 PM
ESARTEE
Mar 16, 2004 10:00 AM
canuck-mx6
Aug 8, 2002 08:26 AM
