Problems with 2-layer headgaskets?
Old Aug 5, 2003 | 02:34 PM
nwdave's Avatar
Default Problems with 2-layer headgaskets?
Can someone elaborate on this:
http://ef-1.zeroforum.com/zerothread?id=160
Obviously MAX_CFM and omniman know what they're talking about, but I'd like to hear other people's opinions.
I'm swapping heads soon and was planning on running a Spoon/Mugen 2-layer to bump compression a tad.
Old Aug 5, 2003 | 11:13 PM
nwdave's Avatar
Default Re: Problems with 2-layer headgaskets? (delsolguy)
No one has any experience with a 2-layer?
Old Aug 5, 2003 | 11:33 PM
F1Spec's Avatar
i personally like to run thinner headgasket due to the fact that they can be changed back if you change your mind.
if you mill the head or deck the block, it can't be undone. with a headgasket, if
it starts to fail, you can just pull the head and change it. yea it takes time but
you have the choice.
i have seen people use 2-layer spoon/mugen in their daily car without any problem. for the record, i use 1 layer headgasket. but i use copper spray with them. motor has seen over 1 thousand miles (not daily driver) and no
overheating or compression loss. (knock on wood)
Old Aug 6, 2003 | 12:59 AM
Beave0101's Avatar
I'm @ 1200 miles since the mugen gasket has been installed, used copper spray, no problems
Old Aug 6, 2003 | 04:00 AM
advanracing62's Avatar
Default Re: Problems with 2-layer headgaskets? (Beave0101)
I've used a Mugen gasket in the past... I'm back on the stock HG wagon now, and notice 0 difference. I agree that milling the head is a bit of a gamble. Once its gone its gone.. Had issues with that before. I would say get your compression from the pistons first. There isn't really a need for the 2 layer HG unless you're going to re-build frequently.
Old Aug 6, 2003 | 09:39 AM
smokey2.0's Avatar
Default Re: Problems with 2-layer headgaskets? (s2geezy)
i been using a 2 layer HG for over a year now, i put about 200-250 miles a week on the car. i have yet to have any problems with it, no leaks, no overheating, etc....
Old Aug 6, 2003 | 11:14 AM
nwdave's Avatar
Default Re: Problems with 2-layer headgaskets? (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">I would say get your compression from the pistons first.</TD></TR></TABLE>
I would, but I just cannot afford that at this time. If I did pistons I'd want to do a 1.8L block, and there just isn't enough $$$ to go around. I'm a huge believer in "doing it right the first time," but I can't do it all at once. As long as the head was off, I thought a upping the compression .2 would just be a way to improve upon the situation.
*shrug* I'll probably just run a 2-layer. I'm only planning on using that setup for a year or so anyway.
Old Aug 6, 2003 | 11:37 AM
Rob Dizzle's Avatar
the mugen adds .4 cr
i talked with austin who is using that on his itr with 37k miles on the mugen headgasket. he has no problems at all so far. and he just checked his cr the other day, and he was around 210 across the board.
Old Aug 6, 2003 | 01:14 PM
nwdave's Avatar
Default Re: Problems with 2-layer headgaskets? (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">the mugen adds .4 cr</TD></TR></TABLE>
Yeah, I don't know what I was thinking with .2 The Spoon raises it by .3 apparently.
Old Aug 6, 2003 | 06:14 PM
cj99si's Avatar
Ive had my mugen for 7K miles (vtec miles), no problems
-Corey
yoorang
16
Nov 12, 2006 04:51 PM
DC5ftmfw
May 20, 2006 01:49 PM
spnfed
Jan 1, 2004 09:03 PM
Renegade
Jul 2, 2003 06:05 PM
Parker69
Jun 6, 2003 01:29 PM
