Installing seals
What do you guys use to install your front oil balancer shaft/crank seals? I have lost my damn seal driver tool and the local parts store does not have any currently in stock.
Ok the oil seals are back in place. One question, on the crank oil seal i have gently tapped the seal back in place. Should the oil pump casing be able to freely spin when touched? Or should it be somewhat 'non-spinning' but easily able to spin when the crank is inserted in it?
Modified by PopeyeTheSailorMan at 6:40 PM 8/5/2003
1SickEG
Jan 28, 2013 03:54 PM
